I need wiring diagram for goodman roof top unit model number pgc090195-3a
  • 116 Answers
SOURCE: Need wiring diagram
check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
Posted on May 10, 2009
  • 182 Answers
SOURCE: Goodman Furnace/AC unit not working
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Posted on Jul 04, 2008
  • 116 Answers
SOURCE: need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
Posted on May 15, 2009
SOURCE: I need wiring diagram for goodman AC unit heatpump/electric
The wiring diagram is on the inside of the door on the blower/air handler unit.
Posted on Mar 19, 2010
  • 9 Answers
SOURCE: i need a wiring diagram
Goodman ck models are very simple in its wiring. Take the panel off of the unit where all the wires come into it. The wiring diagram should be on the inside of the panel.
Posted on Apr 09, 2011
Wiring schematic goodman ph036a serial # 9610058720
Is condenser running? Verify amps to be sure both fan and compressor are operating. Should have 2 wires to compressor and 1 to fan on top of contactor. Then on the capactor (herm) terminal is the remaining compressor wire. On fan and c would be the 2 remaining wires for the outdoor fan motor. Then 1 more wire on c that jumps to the top of the contactor on the other side to which the first fan wire connects. GOOD LUCK.
Mar 19, 2017 | Goodman Heating & Cooling
2002 need model number to answer tonnage
Aug 25, 2014 | Goodman Heating & Cooling
I have a goodman ckl30-1l AC unit. The control board for the furnace has went out and I'm trying to find the model number for it. Could someone help me out please?
the best way is to contact Goodman and ask them for the model, in base from the detail that you have. If you have some wiring diagram or instruc. manual you can identify it. if you do not have downloa give your model +mark+serial number and proceed:
www.fitness.manualsonline.com + www.retrevo.com
God bless you
Jul 26, 2012 | Heating & Cooling
Need to know the BTU's of a coleman rv roof air.
The limiting factor is the power available to run the device. Typically, roof air units are around 12,000 BTU.
Unless your rig is wired with a 50 amp service, you will not be able to run more than you have at the present with your 30 amp service. I have found that a rig with a microwave, a roof AC and a TV frequently cannot run all three at the same time. If you do have 50 amp service, you can add the second roof air. Also, if you have a 30 amp service, you can upgrade to 50 but that is an expensive proposition with the cord itself costing around $200.00. You would also have to upgrade the distribution panel and probably have a pro properly split up the load between the two 120 Volt AC buss'.
I hope this response helps you with your deliberation and thanks for your question @ FixYa.com
Aug 06, 2011 | Coleman Heating & Cooling
I need a wiring diagram for a Goodman A/C ck36-18 #9605047933, where can i find one for this unit?
Apr 08, 2011 | Heating & Cooling
KINDLY SEND WIRING DIAGRAM OF DIAKIN PACKAGED ROOF TOP AIR CONDITIONER MODEL UAT08KAY-1
Hi; Call California number 1-310-769-0105 This is from what I can find to be correct.Also make sure You have the exact model and serial numbers. You can find the wiring diagram usually on the inside cover of the electric compartment covers...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
Need wiring diagram for a heat & air package circa 1970 shows model # PGB02408CAA cannot find manufacture name. Has a wall mount thermostat.
I think this is a Goodman unit. Check the yellow pages for a Goodman dealer. They can help you with that. The unit is pretty old but they might be able to find you one
Oct 30, 2009 | Heating & Cooling
I am a ac tech, and i was working on a old carrier unit, wich had no schematic diagram. I need it in order to get the compressors going. if i give you a model # can you please provide one. roof top ac...
you aren't an ac tech number one but i shall overlook that . your question is llike will the sun come up in the north or the south tomorrow. obviously in the east as it has since the earth was created. anyway. all compressors since the beginning of time wire up the same .a wire commonly referred to as the common goes from the contactor to the compressor. usually black in color, hence the old coloqualism Blacks are common. the run wire is from the contactor to the run side of the run capacitor or from the contactor to the run connection on the compressor. hence the old slogan reds run when you point a gun at them. the only wire left is the start wire that come from the start capacitor and is usually yellow . hence the old saying blacks are common, reds run, and yellows are always starting something. very ethnic i know but thats how i was taught.now that the wirings correct check to see volts through contactor are correct and if one side of contactor is not feeding. if volts good then check capacitors with a cap checker. if all else looks good kill power and inspect compressor terminals at compressor. if burned off consider a termilock kit good luck..
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
