Question about Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face
I put my pool light on . the light is on the return spout.the light seem like it stays on approx 3-4 min then clicks off for about 2 MIN IS THIS NORMAL or what should i look for .i just bought the house with the pool any help would be appreciated thanks
    Problem Solver:
  • 10 Answers
YOUR LIGHT COMES WITH A THERMAL PRTECTOR ITS SHUTS THE LIGHT OFF WITH IT DETECTS TO MUCH HEAT
THEN TURNS IT BACK ON ONCE COOLED DOWN
A DIMMER KIT WILL SOLVE THIS ISSUE AND THEY ARE REALLY COOL
HOPE THIS HELPED--CHARLIE--POOL PROS
Posted on Sep 03, 2010
Engine will only fire after 3 or 4 attempts to start. when running-perfect.leave stand for approx 10 min hard to start again.seems like fuel is bleeding off can you help
The return valve on the fuel pump is letting the fuel back into the tank , you will have to replace the pump or fit a no return valve in the fuel line.
Jun 14, 2017 | Cars & Trucks
I want the light to stay on for only 1 minute
I just had my new opener today. try this:
1. press & hold the LOCK button until the lights blinks.
2. if it is a single blink, the timer is 1.5 min.
3. if you repeat step 1, blink twice means 2.5 min.
4. if you repeat step 1......., 3.5 min
5. if you repeat step 1......., max is 4.5 min
May 24, 2013 | Sears Craftsman LiftMaster Chamberlain...
After playing for a while, approx 15 min, the volume dies away leaving some sound but greatly reduced. It then gradually returns to normal volume after about 3 mins. Otherwise all other functions seem to...
Such a long delay and a slow return to volume is puzzling. If the return came back in say 30 seconds, I would suspect 1/2 of the V1 tube (12AX7) might have a failure of the heater. When it has failed see if this tube has TWO points of light in it. The cooling down and warm up would give a 15 second ramp up or down in volume. This tube has a path around it that would sustain a very low volume. Try swapping one of the other 12AX7's into this spot. If the sound totally goes away replace the one that was in V1 at first place and see if problem goes away.
Mar 29, 2011 | Peavey Delta Blues 115 30w All Tube Combo...
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Wont stay on. It'll load for 3 secs then turn off
The Calculator has a feature that takes it into standby after a certain delay of inactivity. Possible values of the delay are 1 min, 3 min, 5 min, 10 min, and 30 min.
In view of this, your 3 sec value seems too short. I suspect that the batteries are depleted.
In OS 2.x, press 5: Settings & status, then 3:Handheld Setup. Look for drop down box to the right of Power Standby, and select a longer delay.
Feb 04, 2011 | Texas Instruments TI-Nspire Graphic...
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Jul 09, 2009 | Hayward 1HP Super Pump II Inground Pool...
I have lost instruction book for Sharp Compact R250A microwave oven-how do I reset the clock?
May be a little late, but... 1. Press Power Level button for approx 5 seconds - you get the 12 hour clock 2. Press again for 24 hour clock 3. Set hours using the 10 min and 1 min buttons 4. Press Power level button 5. Set minutes using the 10 min and 1 min buttons 6. Press Power level button And you are done
Gert
Aug 05, 2008 | Sharp Microwave Ovens
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face Logo
170 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
