Question about Flotec 3.4 Hp Floodmate Submersible Sump Pump
What is the out put pressure of Flotex FPSC4550A-11
  • 43,501 Answers
These are a high volume pump, but they produce only about 10 psi of pressure...
heatman101
Posted on Sep 03, 2010
2003 crankes but wont start has codes 11 14 15 20
11 - Cylinder Identification Sensor
14 - Intake Air Pressure Sensor (Pipe System)
15 - Throttle Position Sensor (for Throttle Valves)
20 - Intake Air Pressure Sensor / Atmospheric Pressure Sensor
with those codes being tripped im guessing there is a major vacume leak, or no engine compression.
Aug 06, 2014 | 2003 Yamaha YZF-R1
Audi a4 1998 all engine names/parts
Check the help link related to Acura car models:---
How to Clear OBD error Codes on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list for Acura Car Models?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
Underhood components http://www.howtorepairguide.com/2012/11/lincoln-underhood-components.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace Power Steering Pump on Acura Car Models?
Also bleeding:
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to replace Steering Linkage on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-linkage-on.html
How to replace Steering Wheel on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-steering-wheel-on-acura.html
How to replace Power Steering Pump on 1999 Acura TL? http://howtobyme.blogspot.com/2011/11/how-to-replace-power-steering-pump-on.html
How to Test and Replace Fuel Injectors on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-fuel-injectors.html
How to replace Fuel Tank Assembly?
http://vwrepairhelp.blogspot.com/2011/11/how-to-replace-fuel-tank-assembly.html
FUEL LINES AND FITTINGS on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/fuel-lines-and-fittings-on-acura-car.html
Replacing Fuel Charging Assembly on Car?
http://vwrepairhelp.blogspot.com/2011/11/replacing-fuel-charging-assembly-on-car.html
Intermittent Charging Problem with Engine warning Light?
http://whoisbyme.blogspot.in/2012/07/intermittent-charging-problem-with.html
How to replace Fuel Pressure Regulator on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-fuel-pressure-regulator.html
How to test Fuel Pressure and replace Fuel Pump on Acura Car models? http://repairhelpcenter.blogspot.com/2011/11/how-to-test-fuel-pressure-and-replace.html
These will help.
Thanks.
Nov 22, 2012 | 2004 Audi A4
Where is fuel pressure regulator
For fuel related problem, the help links are provided below.
Click the link below to go through its procedure: ----
How to relieve fuel pressure?
http://technoanswers.blogspot.com/2012/01/how-to-relieve-fuel-pressure.html
Refueling problem?
http://repairhelpcenter.blogspot.com/2012/01/refueling-problem.html
Car consuming more fuel?
http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html
How to maximize fuel economy on your vehicle?
http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
Fuel pump relay troubleshooting ?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
How to Increase gas mileage vehicle?
http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html
How to Test and Replace Fuel Injectors?
FUEL LINES AND FITTINGS ?
How to replace Fuel Pressure Regulator ?
How to test Fuel Pressure and replace Fuel Pump?
Car will not take fuel into the fuel tank?
http://repairhelpcenter.blogspot.com/2012/01/car-will-not-take-fuel-into-fuel-tank.html
PGM-FI Main Relay location?
http://repairhelpcenter.blogspot.com/2011/11/pgm-fi-main-relay-on-acura-car-models.html
How to Relieve Fuel System Pressure on Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-relieve-fuel-system-pressure-on.html
How to Replace a Fuel Injector
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-injector.html
How to Replace a Fuel Pressure Regulator?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-pressure-regulator.html
How to Replace a Fuel Pump?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-fuel-pump.html
HOW TO CLEAN A FUEL SYSTEM
http://schematicsdiagram.blogspot.com/2011/07/how-to-clean-fuel-system.html
HOW TO REPLACE A FUEL TANK
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-tank.html
HOW TO REPLACE A FUEL TANK CAP
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-tank-cap.html
HOW TO REPLACE A FUEL PUMP ASSEMBLY
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-fuel-pump-assembly.html
How to change fuel injector on gmc ?
http://schematicsdiagram.blogspot.in/2012/03/how-to-change-fuel-injector-on-2005-gmc.html
Time to replace Fuel pump?
http://schematicsdiagram.blogspot.com/2011/12/time-to-replace-fuel-pump-on-1998-ford.html
Emergency fuel shut switch location?
http://schematicsdiagram.blogspot.com/2011/12/emergency-fuel-shut-switch-on-ford-car.html
How to jump fuel pump?
http://schematicsdiagram.blogspot.com/2011/12/how-to-jump-fuel-pump-on-chevrolet.html
Car wont start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
Car wont start after sitting overnight?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-after-sitting-overnight.html
Car loses power while acceleration?
http://schematicsdiagram.blogspot.com/2011/12/car-loses-power-while-acceleration.html
Fuel leaks from fuel pulsation dampener?
http://repairhelpcenter.blogspot.com/2012/01/fuel-leaks-from-fuel-pulsation-dampener.html
Car will not allow to put fuel?
http://repairhelpcenter.blogspot.com/2012/01/car-will-not-allow-to-put-fuel.html
Adding performance chip to increase Fuel mileage MPG?
http://technoanswers.blogspot.com/2012/01/adding-performance-chip-to-increase.html
How to test Electric fuel pump?
http://technoanswers.blogspot.com/2012/01/how-to-test-electric-fuel-pump-on-gmc.html
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Fuel pump not working on Ford?
http://technoanswers.blogspot.in/2012/01/fuel-pump-not-working-on-1991-ford.html
Fuel pump has no power on ford diesel?
http://technoanswers.blogspot.in/2012/01/fuel-pump-has-no-power-on-2002-ford-350.html
Pushing on the gas pedal but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
Ford Fuel pump Relay and fuse location diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-relay-and-fuse-location.html
Ford inside fuse box diagram showing fuel pump relay?
http://technoanswers.blogspot.in/2012/02/ford-inside-fuse-box-diagram-showing.html
Ford fuel pump fuse layout diagram?
http://technoanswers.blogspot.in/2012/02/ford-fuel-pump-fuse-layout-diagram.html
How to lower fuel pressure on
Toyota?
http://schematicsdiagram.blogspot.in/2012/02/how-to-lower-fuel-pressure-on-toyota.html
Fuel pump not running?
http://schematicsdiagram.blogspot.in/2012/02/fuel-pump-not-running.html
How to replace fuel filter on BMW?
http://schematicsdiagram.blogspot.in/2012/03/how-to-replace-fuel-filter-on-bmw-525i.html
This will help.
Thanks.
Feb 19, 2012 | 2010 Volkswagen CC
Where is the fuel pressure regulator located in my 1994 safari 4.3 liter
Refueling problem?
Toyota?
This will help.
Thanks.
Feb 05, 2012 | 1994 GMC Safari
98 Buick Regal LS 3.8L how do you relieve pressure on fuel line prior to changing fuel pressure regulator
For fuel related problem,the help links are provided below.
Click the link below to go through its procedure:----
Refueling problem?
How to lower fuel pressure on Toyota?
How to replace fuel filter on BMW?http://schematicsdiagram.blogspot.in/2012/03/how-to-replace-fuel-filter-on-bmw-525i.html
This will help.
Thanks.
Feb 04, 2012 | 1997 Buick.5 Regal
We have a fpsc4550A sump pump and it turns on but will not shut off the float seems to go up and down with the water level
The switch is at the top, and the float is supposed to push on the switch.
If there is anything between them, or the switch is stuck, it may not work right.
Push up on the switch manually with a piece of wood (don't like to use fingers with electricity and water), to see if you can operate it with more force.
If you can, then lift float to see if it is heavier than it should be, perhaps from leak or accumulated algae weight or something?
http://www.pumpagents.com/FlotecPumps/FPSC4550A.html
Feb 26, 2011 | Flotec Plumbing
I have a Flotec pump model #FPSC4550A that will not stop running even though the float falls down. Any ideas?
Sounds like the contact inside the float is stuck. It can be corroded and not letting the circuit open and that will keep the pump running.
If it had been fine but just started doing this, that is what I'd check. If someone could have accidentally wired it incorrectly when they were trying to fix it, perhaps they accidentally bypassed the float switch and have it "running hot" all the time.
Feb 04, 2011 | Flotec Automatic Sump Pump Float Switch
11 black lines
your display is damaged so replace it . you have no other go
Aug 27, 2009 | Sony Ericsson W200i Cellular Phone
WHAT IS THE TORQUE PRESSURE FOR THE BOLTS ON A 2000 CHVROLET GRA
Good day;
the torque is the following
step 1. 37 Ft lbs (50 Nm)
step 2. additional 130 degrees
step 3. for c, h, and w bodies the four center bolts additional 30 degrees.
if you don't have the the torque sequence here it is
6 1 3 7
8 4 2 5 this is the head
11 1 3 10 8
5 7
6 12 4 2 9 this is the lower intake 11 Ft lbs (15Nm)
hope this helps
Cheers
Jul 13, 2009 | 2000 Pontiac Grand Prix
Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
105 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
