Question about Maytag CWG3100A Gas Single Oven
I just bought a Maytag build in oven cwg3100aaae29. It dose not have a cover around the light bulb, what happen?
    Genius:
  • 1,075 Answers
Some new types of bulbs do not require a cover as they can withstand the heat,if in doubt ring your supplier.adrian,,,,
Posted on Sep 03, 2010
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
How to change the light bulb in a maytag 8114P732-60 oven
Hi Mary. I had a bad bulb in my Maytag new from the factory. I also had a hard time getting the glass lense cover off, and didn't want to be too rough with it for fear of breaking it. But it WILL come off if you turn it hard enough. I've since seen suggestions about putting warm water on it to loosen it up. And another person wrote and said using an oil filter wrench on it worked like a charm.
Good luck
Jul 27, 2014 | Maytag CWG3100A Gas Single Oven
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
How do remove the oven bulb cover in a maytag precision touch control 800?
the trick is to push the metal ring IN at the same time as turning the bulb cover counter clockwise
Feb 01, 2013 | Ovens
How to get oven light cover off to change bulb
If you were looking directly at the lamp cover you would need to turn it ant clockwise, if it really tight, pop on a pair of rubber gloves, get a good grip on the cover and turn it right to left. If you still can't move it, contact neff service (0844 892 9002 in the UK) and advise them of the problem, they should send you out a removal tool which basically is a plastic cup that fits around the cover, it has a build in handle and will assist in the covers removal. Hope this helps. Let me know the outcome or if I can be further assistance.
Nov 10, 2011 | Neff Ovens
I had a burnt out element in my Maytag oven and had to take back off oven and follow the wire that went into the element holes. I know how to fix the element and wires with that. I noticed that the...
dont worry about insulation missing i have worked on ovens for many years and often bits are missing from earlier repairs and the oven will work fine.
Aug 27, 2010 | Ovens
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
Jan 12, 2009 | Ovens
Maytag CWG3100A Gas Single Oven Logo
62 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
