Question about HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor
Compaq 1720 monitor: the green light on the power supply went away, the voltage converter was very hot and the monitor went blank
  • 11,361 Answers
You need to find out if the power supply is still putting out 12vdc, you may have to test it with a load (use 12v car bulb such as the brake lamp). It is getting hot can be due to bad power supply or too much load because of short circuits in the monitor. Please post back what you find about the power supply first.
http://www.unitedsale.com/AC-adapter-Power-Cord-Charger-12V-35A-For-Compaq-1720-LCD-Monitor-Brand-New_p_219.html
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 03, 2010
Hi, My Relisys monitor does not start at all, even the green LED went off. At first, it begun with sudden shut-offs on its own, then it became a permanent out-of-service. Please give me a hint for a...
The power supply (the part of your monitor that converts the AC line voltage - taken from your wall plug - into the various voltages required by your monitor) inside you monitor has failed. If you have the expertise and test equipment you can diagnose the problem and determine which component within the supply that has failed.
Aug 09, 2011 | Relisys Intro TE770 17" CRT Monitor
My Compaq 172 monitor won't stay on but for maybe 30 seconds then goes blank. When it does this, the on/off button is still lit up, but I have to lush it manually to get it back on for about another...
Failing Power capacitors. The capacitors hold the charge necessary to build up the voltage that lights the screen. When they leak or fail to hold the charge, the screen will cut out. It could also be a fault in the switch circuitry. Really needs looking at by a qualified technician.
Jul 21, 2011 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Blank screen, no light indicating monitor is on, makes clicking noise when i click to turn on. It is a hp mx705.
It is either the power supply or the deflection circuit.
If you can read electronic circuits and know how to use a DVM. Check the power supply voltages and the deflection circuit for any short..
Best of luck.
www.aaatvservice.com
Mar 04, 2011 | HP Compaq FS7600 17" CRT Monitor
The monitor led is green but it gives white flash and still blank
Check the volatage regulator in the mainboard resolder all you found dried unsolder parts inside mainboard. Voltage test the regulator IC if have a voltage flow 2.5 to 5v DC. check ribbon cable connector from mainboard to controller board if properly connected. In the controller board find the small fuse test it for open.
Reminder:
When you voltage test in the power board
in the primary section of power supply
use hot ground. Do not use the hot ground
when you voltage testing the secondary
power supply, mainboard and controller
because it will cause of damage
semiconductor. For safety use cold ground
for secondary, mainboard and controller
board.
Aug 29, 2009 | ViewSonic VA712 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Compaq 1720 Monitor display comes on for 5 minutes and then goes off
change the main capacitor of power supply section .Hope this solution works.
Aug 01, 2008 | Compaq CV 7500 17" CRT Monitor
Compaq tft 5000 out of work
Your backlight probably went out and needs replaced.
Jun 18, 2007 | Compaq TFT5000 15" LCD Monitor
Compaq Monitor
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Aug 07, 2006 | Compaq fs740 17" CRT Monitor
HP Compaq 1720 (Carbon, Silver) 17" LCD Monitor Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
