Question about Dishwashers
My blanco bfdw6x dishwasher has the folowing symptoms - power on, 30 min wash cycle set, after pressing start cycle button the machine sound likes it tries to start, but then cuts out and the digital display shows 0000. Turning the machine off and back on again, resets the display to original setting, but same thing happens ie cuts out again. What process of elimination should i try before getting a technician out? Thanks
Ours does the exact same thing. We pull it out and tip it which drains some water on the floor and then it works. It is something a technician told us ages ago, something to do with a water level switch underneath.....but its driving us mad. We have to do it on a regular basis. Does anyone know how this can be fixed more permanently. thanks.
Posted on Sep 22, 2010
  • lynnefixed Jul 31, 2011
    Thanks so much ellybelly24. This advice worked a treat. My blanco BFDW8 is now working again. Saved us a call out fee for such a small problem. Really appreciate you taking the time to put this on the net. Regards Lynne 31/7/11
  • jcm03 Aug 13, 2011
    My has done the same twice to me and it turned out a seal at the back of the machine had a tiny puncture hole it that was causing the problem. I've had the seal replaced twice.
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
Fisher and paykel nautilus. Cycle stalls with 15 mins to go. On any setting.
OK, when you say it sounds like a record skipping does that mean its washing then not washing? what cycle are you using ? sorry to ask these questions but sounds like an unusual fault.is the water hot? could be control module or pressure switch fault. please reply and we can hopefully track down this fault.
May 22, 2010 | Fisher and Paykel 24 in. DS603H SS...
I have a Blanco Dishwasher
Try unplugging it from the wall socket and leaving off for about 1 min then plug in and turn back on
Aug 14, 2009 | Dishwashers
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,030 people viewed this question
Top Dishwashers Experts
