Question about Vacuums
I need an operators manual for a D100 digital time switch
  • jmkelly145 Sep 03, 2010
    I need a manual for a tork D100 time switch, not a Nikon camera manual or a vacuum cleaner
    One more time. It is an old Tork time switch D100.This is a 1st generation digital time switch. It is not a dishwasher or a vacuum. It is not a DG100 or DD100. I need the operators manual.
    President:
  • 1,961 Answers
It will be very easy for us to help you find your manual if you specified the brand name of D100. Please post back
Posted on Sep 03, 2010
  • 3,247 Answers
Please confirm it is Tork DG-100 and not D-100.
  • Vacuums Master
  • 4,924 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/NIKON/D100-_E
I hope this was what you were talking about ..and I didnt make a confusion ..
to download ..just click on the download the complete userguide..than rate it max..and will start downloading ..
  • Catalin Turcu
    Catalin Turcu Sep 03, 2010
    Ill see what it can be done ..is not my fault that you didnt specified the make and model for what you need..
Where the on and off switch
On the hand grip (pistol grip) as shown in the owners manual. If you do not have a manual you can download one for free from www.dyson.co.uk
Oct 07, 2014 | Dyson Digital Slim Dc35 Multi Floor...
After powering on my sony rdr hx-750,the wellcome message stays on for a long time and it tells you CANT USE THIS after switching to dvd mode
You can download the instruction manual for your product at http://pdf.crse.com/manuals/2899893131.pdf Please try following the instructions listed for the use of the DVD mode and see if you are operating it correctly.
Regards, Kat
Aug 19, 2011 | Vacuums
Can the GE 15086 digital timer be wired to work on lights operated by two 3-way switches? The package indicates it is a single pole switch and needs a neutral wire. If it can be used, what happens with...
GE 15086 7-day programmable timer will not work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
It is possible to wire GE timer in place of a 3-way if you tape the other switch in one position.
Add a comment if you want help with that wiring.
There are several 7-day programmable timers that can be wired for 3-way. Each of these is wired slightly differently, and you have to look at wiring diagrams carefully. But they are completely do-able.
Links below go to pages that show manuals and information.
Aube T1032
Aube T-1070 7 events
Aube T-1073 21 events
UPM ETW193 20 events
UPM ETW350
Brinks 46-1022
Intermatic ST01C 40 events
Intermatic EJ500 40 events
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Vacuums
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
U5470-900 stuck switch
I had the same problem twice already. The first time it was under warranty and my local vac & sew shop fixed it for free. The second time was shortly after warranty expired, so I just bought the switch and replaced myself. Have only had it for 2 years, so we'll see if I have to replace the switch again in a year.
Jan 08, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Cannot shut vacuum on hose
Will the main unit operate if you switch to manual operation. If so, then it could be that the PC board has a stuck relay and you will have to replace the PC Board. Could be the switch inside the handle. You take your hose to your local dealer and or someone that you know that has a beam system and plug it in and see if it works or not. If it does, then it is in the main unit, if it doesn't. then there is a problem with the hose or switch asm.
Nov 21, 2007 | Beam Industries 2775 Serenity Plus Central...
Vacuums Logo
122 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
