FixYa.com
Tags:
Brother HL 1440 Laser Printer
Brother HL-4040CN won't read or show new refilled...
posted by Sunny10 on May 11, 2008
Please help. My HL-4040CN is only 3 weeks old. Two days ago I refilled my yellow cartridge, it works and the print quality is as good. Today I refilled my magenta cartridge and to my disappointment the LCD don't show or read the magenta refilled cartridge, and the printer won't print.
Comment by Sunny10, posted on May 11, 2008
Thanks for your reply, mine is a laser colored printer and it's a toner cartridge. Yes I have the correct toner cartridge and have cleaned the corona wire and the drum according to the manual. Still not being read by the LCD monitor. Thanks again.
As I stated earlier I refilled the magenta toner cartridge meaning it's the correct cartridge. I cleaned too the corona wires and drums according to the manual and did the re-installing, still LCD won't read the newly refilled magenta toner cartridge. I am still hoping though that someone can give me a solution so I will be able to save a lot through refilling. Thanks for trying.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
adam8117
Rank:Wiz Wiz
Rating: 83%, 29 votes
Obviously, you would want to make sure you have the correct cartridge for your printer model. If you have the correct cartridge, remove the magenta cartridge and make sure that some tape was not left behind on the contacts. Clean the copper contacts and inside the the ink carriage with an alcohol dampened towel. Re-install the cartridge (making sure it is pressed in all the way). Turn the printer off for 30 seconds and turn it back on. If this does not solve the problem, I would try a new ink cartridge, and if that fails I would return the printer.
Rating Locked! (?) Sunny10 has rated this solution as Thanks for Trying
Solution #2
posted on Jul 15, 2008
Not Rated (0)
Ssh3
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Q: Brother printer toner refill.?
A: yes and no. it is easy to fill the toner but if it is the original toner which came with the printer, they deliberately leave out a $4 starter gear which is needed to regulate the amount of charge going to the drum. Without this gear, the copies will come out too light and be nearly useless. I threw out two of these printers until I came across Northbay Toner who explained this to me and provided what I needed. I now have two Brother lasers working well on $5 refills. For more info, see http://ccs-digital.com/northbay.html
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Reset gear needs to be adjusted...
Can you Help with these Printers problems?
Installing w/o Disk
I'm trying to install a brother... Answer This...
Won't p[rint
Yesterday, I tried to cancel a... Answer This...
Internal Part
I was flushing with air the... Answer This...
blinking lights
ready-alarm lights kept... Answer This...
Paper keeps jamming
Will not print using cardstock... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
