Question about HP Compaq Presario SR1920NX PC Desktop
How do I install more memory...We just purchased a 1 gb ddr and I just would like to know the proper way to install it.
  • 8,197 Answers
You can learn how to install memory on the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&dlc=en&cc=us&product=3184154
Good Luck and please rate 4 thumbs up fro the free answer
Posted on Sep 03, 2010
Just installed 2 512 mb memory but when i turn the laptop on the fan turns on and the lights blink but it works fine with old memory. and others have upgraded memory to 2 gb when the max is 1 gb and theirs...
Sound like you have two questions:
1) Why does my new memory not work?
2) Can I upgrade to 2 GB?
For Question #1, my thought is that maybe the new memory does not match up the laptops specifications. According to Gateway's website, "This notebook has two 200-pin industry standard DDR-SODIMM sockets that can accept 266 MHz DDR RAM memory module." Is the new memory 266 MHz? If not, that could be your problem and you should get the appropriate type of memory.
If the memory you purchased is 266 MHz, you probably have defective hardware and should seek a refund or replacement.
As for Question #2, you can try it but you may waste your money. If the manufacturer says the max memory allowed is 1 GB, it probably is true. I would only try it if you could get free, cheap or borrowed memory.
Mar 11, 2011 | Gateway M305CRV Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
VGA Adapter stops working after memory install
Wrong memory speed.  333 max. 2GB Max
Below taken for you support site (See Link)
MEMORY ecs_buttom_03.gif  2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif  Support DDR333/266 DDR SDRAM
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=465&CategoryID=1&DetailName=Specification&MenuID=45&LanID=9
Feb 19, 2009 | EliteGroup 845GV-M3 Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Windows xp
hi
is this your motherboard? http://shop.pcmag.com/shop/product_specs/Intel+D915GAG+BLKD915GAGL10+Motherboard/22673983.aspx
if so, it is ok for you to upgrade your memory up to 2gb. btw, just be sure to properly install the rams to the slots.
since youve purchased 2 x 1Gb ddr400 , put on color blue slots.
hope this helps
Jan 23, 2008 | Intel D915GAG Motherboard
HP Compaq Presario SR1920NX PC Desktop Logo
24 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
