Question about Kitchen Appliances - Others
Trying to wire a general motors blower#5kcp39hgP968bs with a fasco d727
2 Suggested Answers
farfield
  • 462 Answers
SOURCE: replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Posted on Mar 13, 2009
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
Fasco model d917 wiring diagram
Well, a Fasco is a generic brand name of HVAC replacement motors.... a little more information would be helpful....like the wire colors???? Each Fasco motor has a wiring diagram on its side and is self-explanatory. Post a picture of the diagram and it will be much easier to walk you through the procedure.
But TYPICALLY....white is common
black is high speed
red is low speed
blue and yellow is medium low and medium high
two brown wires go to the capacitor
Some manufacturers have oem motors that have a few different colors.
May 13, 2014 | Goodman Heating & Cooling
Fasco d236 replaces 7190-1186 u90B1 - wiring cross reference?
Is this a water heater blower? Or HVAC?
Post question on water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
I do not have HVAC resources
Add a comment and say what you discover
Jun 28, 2013 | Water Heaters
Janitrol GMP 100-4 replacing blower new blower has extra yellow wire. do I just not connect it
Look on the motor wiring diagram, being that it is yello would lead me to believe that this is
a muti-speed blower. If this is true, look for a place on the terminal board that says "Park"Otherwise make sure you tape it off and move it out of the way
May 26, 2011 | Goodman Furnace Draft Inducer Blower ...
Where can i get replacement bearings for a fasco blower motor?
Climate technology deal with fasco pumps , maybe motors too
Apr 27, 2011 | Heating & Cooling
All I have is this Fasco # 71902773. Need the "D" number to know what to order
"D", when refering to an electric motor, is a dimension; it is the distance from the 'bottom' of the motor to the center of the shaft. I'm not sure why you would need it but if you do, sit the motor on a flat surface and then measure from that surface to the center of a shaft and you'll have the 'D'.
Your Fasco motor was made for Greenheck...google the model number and several sources come up such as this one: When searching use "Fasco 7190-2773" as the search phrase...
http://www.emotorpro.com/greenheck-115-volt-1100-rpm-oem-fan-motor-fasco-7190-2773---304970.aspx
John
Apr 01, 2011 | Fasco Centrifugal Blower 115v
Replacing blower motor in furnace w/Fasco brand #D727
Black Hi
Blue Med
Red LO
Mar 13, 2009 | Kitchen Appliances - Others
Draft inducer blower going bad
I agree close enough. Only slightly slower. If it fits mechanically , useit.
Jan 17, 2009 | Omega Trane Furnace Draft Inducer Blower...
I would like to find a owners manual.
hacve oyu tried Fasco Industriess yet. Yoru blower shouuld had 4 wire on it and come on imediately with a call for heat. the second set of wires are basically a saafe3ty that closes when the unit is spinning they close telling the board or contrller that the fans running. Good Luck and Hope this helps if notthen you can contact me here if ypou care to.
Jan 04, 2009 | Cross Furnace Draft Inducer Blower 115...
Kitchen Appliances - Others Logo
79 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
