What happen if the cold fill up slow and the washer dont ring out all the way and the washer keep stop on rinse
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to
fill then read these tips. I have covered many of the things that can happen in
these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may
not align perfectly but don't worry, just get them to go back in the
hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
SOURCE: Ge washer wont stop filling with water
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
