Question about Chicago Pneumatic 3/8" Heavy Duty Air Ratchet CP828
I have a benchtop ratchet wrench, taken apart to be cleaned, but im not sure were the spring and the ball bearing goes
There is a hole that goes down inside the handle that the spring goes in. The ball goes on top of the spring. The trick is compressing the ball
Posted on Oct 01, 2010
Parts manual for a 5040 1/2'' air impact wrench
MUITO OBRIGADO EU NAO ACHEI EM LUGAR ALGUM?
TANK VERY MUCH.
Jan 26, 2012 | Air Tools & Compressors
Handle and spout is to hard to move.
The bonnet nut may be to tight.Turn off water to faucet and remove handle with allen wrench at set screw then unscrew bonnet nut to reveal bonnet washer and valve ball there are also springs and washers(take note how it is taken apart because it must go back in same way it came out)then clean all components use some plumbers grease or vaseline to coat parts when replacing it will help in the movement of handle also,(you may want to put in repair kit since you have apart,availabe at home improvement,hardware,plumbing supply stores,I do recommend this).
May 30, 2011 | American Standard Jasmine 3821.644.295...
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
Very little power to craftsman 3/8 ratchet. air pressure set at 80pi.
add a few drops of marvel mystrey oil to the ail line opening to clean it out and try it again
Feb 24, 2010 | Craftsman 3/8" Pro Air Ratchet Rapid...
Spring loaded ball bearings - does the ball bearing sit on top of the spring or below the spring??
The ball bearing is a check valve. The ball should be in the input side of the water with the spring underneath.
input side ----->( O/////)-------> output side
Feb 21, 2010 | Jura Capresso Capresso Infinity Conical...
Need to know how to assemble air connector where the spring is with metal ball bearing which goes first
the "male" end (without the spring and ballbearing) sticks out of the bottom of the tool handle; the "female" connector goes on the end of the hose furthest from the compressor.
Nov 18, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
When you put a socket on my 3/8 air ratchet you can hold it and it doesnt turn the socket
Make sure your tank is pressurized before using, Also, ratchets have an air adjustment knob that you can adjust how much pressure and power the ratchet puts out. Make sure you oil ratchet before each use with air tool oil
Aug 24, 2009 | Air Tools & Compressors
Air impact tool does not engage but will eventually engage after switching directions.
Although I do not have a Craftsman, I have taken severl othe brands apart. They all seem to be much the same. You do not need specialized tool. You just have to be mechanically savey. I think the grease has thickened up too much so taking it apart and cleaning it should do the trick. Start at the working end end and separate the front end. Work on a clean bench where little items (screws, ball bearings etc) won't roll off and get lost. When the two parts are separated, you should see the hammer mechanizm and a lot of grease. remove and clean everything that you can. Re-lube the mechanizm with a light lube grease and re-assemble. Turn the socket drive by hand to make sure everything is free, then apply a liberal application of air tool oil to the air port of the gun and attach an air line and give it a try . Put a load on the socket to check for impact functioning properly. I hope this helps
Jun 02, 2009 | Ingersoll Rand 271 Super Duty 1 Inch...
Chicago Pneumatic 3/8" Heavy Duty Air Ratchet CP828 Logo
391 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
