Question about Apple iBook G4 Mac Notebook
Stop working ibook g4
After 2 years the computer stoped, i try with discs, with external help, but nothing
someone told me may be the board is the problem
It sounds like the hard drive has quit. I had the same thing happen to my G4 and took it to the Apple store today. They checked it out and said that the hard drive was gone. They told me that I could have it replaced by them for about $300 with a 90 day warranty. If you can replace it yourself, you can get a new drive a lot cheeper.
Posted on Jul 23, 2008
Http://coreyarnold.org/ibook/?p=20
Posted on May 13, 2008
When I turn on the mac iBook G4 it says you need to restart the computer, and when I did it just gives me a black screen and it chimes but nothing else.
Try SMC and PRAM reset. To do this you need to google the model number and the reset instructions. If that does not work you need to reinstall the OSX
Feb 23, 2013 | Apple iBook 12 iBook G4 1.33GHz,...
External wont open on mac
if you have used the hard drive on a windows pc some format types cannot be recognized by mac
follow these steps to make it usable by mac and windows
*THIS WILL DELETE ALL FILES ON THE EXTERNAL HARD DRIVE AND DOE NOT ALWAYS WORK
Go to Finder -> Application -> Utilities
Double click for Disk Utility
Select the external Hard Disk you wish to format at the left column
Click on the Erase tab
At the “Volume Format” select “MS-DOS File System”
If you confirm to format your hard disk for mac and windows, Click on “Erase” button.
Pop up window will ask to verify the erase procedure. Click the erase button again in the window to start the erase process.
Once the erase process finish, your external hard disk may be able to use in Mac and Windows.
Mar 20, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
I cant get my ibook g4 to run it turns on with blinking folder
Blinking ? mark folder means that your OS can't be found. Take out your RAM underneath the keyboard and re-insert and try again. Nothing? Install a different new RAM chip and try again. Nothing? Install your disc 1 install disc, power down, wait a few seconds, now press the power button to turn on, now press and hold the option button, until your disc 1 shows up, select it, and bring your pointer to the right arrow on the screen and press enter. Now your booting from the disc 1. Go to disc utility folder at the top of the screen and select your hard drive and then select repair disc permissions. Then shut down and reboot when finished. Nothing? Your hard drive is fu.k.d-Try re-installing the OS. Nothing? Your hard drive is really fu.k.d-You need a new hard drive. Installing a new hard drive in the iBook is a *****. You may want to pay someone to install a hard drive or you can just get a new laptop.
Mar 09, 2010 | Apple iBook G4 Mac Notebook
My ibook G4 has stopped reading my external dvd drive.
If you external DVD drive connects via USB, try rebooting your iBook. (Sometimes a static shock will shut down your USB channel, and only a reboot will reset it.)
If this doesn't work, choose "About This Mac" under the Apple menu, then click on "More Info." Under Hardware, click on USB. See if the drive shows up as one of the attached USB devices. If it does not, the drive or cable may be bad.
If you have another computer available, connect your DVD drive to it. This will tell you whether the drive has failed.
Nov 14, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Hey, I have been trying to turn on my Ibook Mac for two days and I am unable to upload the computer. What happens is when it comes on a Screen showing the Apple icon with the round circle object loads for...
Sounds like your hard drive is failing.
Try booting while holding down the shift key that will put you into safe mode and run some diagnostics at the same time.
If you have the discs that came with the laptop try booting from them while holding down the D key. That will bring up AHT a built in test for your mac. You can use it to test and repair some of the disc problems you are describing.
Sep 09, 2009 | Apple iBook Mac Notebook
IBook (Where is the Video Card)
If you are getting a blue screen, you computer has loaded into the User files, you user files are corrupted and are causing this problem. Having a known good drive to start off of, you can fix this problem rather easily.
Feb 15, 2009 | Apple MacBook Mac Notebook
LCD / External VGA output problems
Hi
If you are still faced with this problem.....
Possibly the video card has gone in the unit. The original screen on the laptop may have had an blown inverter which would not stop the funcioning of the external display. However for the external disply to stop working would suggest the video card. Before going this far have you checked to see if there is power to the external monitor? Have you tried the monitor on another computer? If the monitor works with another computer you can be certain there is more wrong with your poor old iBook. You will need to take it in to be looked at.
Hope this helps.
Regards
Apr 20, 2008 | Apple iBook G4 Mac Notebook
Ibook G3 will not start
If you stilll have the Mac OS installation CD available the when it is starting up press down C and it will start from the Mac OS X installation Set up then you can reinstall OS X and it should work.
Apr 17, 2008 | Computers & Internet
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
Apple iBook G4 Mac Notebook Logo
132 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
