Question about Dell Dimension™ B110 PC Desktop
Dell Dimension B110 will not power on when front button is pushed. Plugged it into another outlet without using power strip....still didn't start...purchased New power supply and installed still nothing when pushing front power button
    Sergeant:
  • 172 Answers
Check the bezel/power button
try to open the tower but you have to make sure that its unplugged/ after unplugging the power cable press the power button for about 5 secs to drain the flea power then check the power button maybe its broken or the cable connected to the power button to the main board is damaged or loose.
Posted on Sep 03, 2010
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
When I push the power button on my Dell Dimension B110, nothing happens. There is power to the board, as there displays a green light. What shall I do?
take a look inside ..maybe wires are loose or something like that .. and while you are doing that ..remove the ram memory also ..and check them one by one ..and see if it boot-up or not ..also remove the bios battery and place it back ..If by mistake you selected something in bios related with the power button or the way it will boot up ..this will default the bios and will get it back to the factory settings ..and it may work if it is something related with it ..
Otherwise..I can not see what the issue may be ..but a faulty motherboard..or something related with the cpu ..try to see if the fan is working ..If this is unplugged or malfunctioning ..it will cause the cpu to stop the boot up ..
Oct 22, 2010 | Dell Dimension B110 PC Desktop
How do I open a Dell Dimension B110 Case?
If you look on the top near the back there is a black oval looking button...you have to press that down...ALSO you have to press the same button on the bottom of the machine. It opens like a wallet but you have to press those oval buttons to release the latch.
Aug 19, 2010 | Dell Dimension™ B110 PC Desktop
When i cleaned my dell demension i put everything back exactly how it was now when i turn on my computer none of my external devices mouse pc screen keyboard is not turning on i need help
I would first check and verify that the electrical outlet or power strip that they are plugged into is working. If a plug gets in a bind it could have blown a fuse on the power strip or the power strip might have a reset switch on it. Or the power strip might have failed. If you have a uninteruptable powersupply that you plug everything into you will need to confirm that it is working as well, test it and look for reset buttons or a fuse holder on it. Your electrical cords could have been pulled out from the wall outlet itself while cleaning sometimes even wall outlets if put in a bind from pressure will blow a fuse or the cord might pull out just enough that it is not making a good connection.
You might get a lamp with a bulb that you know works and plug it into the same electrical receptical that you have the dell computers power cord plugged into and then test the monitor power source the same way.
If the outlets or power strip are getting power and that is confirmed by testing them, and then you plug in the Monitor and Dell power cords into the sources that you have confirmed are getting power, and they do not come on we have a different problem.
If the monitor is hooked up wrong to the computer or not even hooked to the computer the light should come on on the front of the monitor incicating that it is getting power. If you plug it into a confirmed working electrical outlet the light should come on on the power button of the monitor. If it does not come on then somehting might hve possibly damaged all of the epuipment that was plugged in like a power spike on the electrical lines going into your home, this would be very rare but not impossible.
I am sorry for all of the senerios but you were not really clear on what you were using as power sources going to the equipment and I wanted to try and cover the most common possibilities in one email. Please let me know if this helps
Aug 02, 2010 | Dell Dimension E521 PC Desktop
Qiuck orange flash light when i start my dell pc
that means that its has problem recieving power or a power supply could be going out soon make sure it is plugged in directly to the wall outlet on no power strip or multi-outlet.Check the black power cable in the back computer . Make sure its tight in there.
May 14, 2010 | Dell Dimension 4700 PC Desktop
Inspiron b110 wont turn on only green flashig
Unplug your computer, wait 30 minutes, plug it back in and try again.
If it still doesn't work, it's got a serious problem. If it isn't under warranty with DELL any longer, take it to a reputable repair facility.
Apr 14, 2010 | Dell Dimension™ B110 PC Desktop
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
Mouse and keyboard suddenly stopped working on Dell b110 desktop
Disconnect external peripherials except keyboard and mouse .Disconnect the power cable.Hold the power button for 10 seconds to drain flea power.Reconnect the power cable and turn on the computer When the blue DELL™ logo appears, press immediately. In bios there is option for Function key F9 or F10 probably to reset to defaults.SAve and exit and restart the system .Then try to use the PC restore feature on dell. check http://support.dell.com/support/edocs/systems/dim1100/en/SM/syssetup.htm#wp1055545
Good Luck.
Apr 05, 2009 | Dell Dimension B110 PC Desktop
Power failure
by plugging it directly into the wall... what was it plugged into before. and have you actually taken some other electrical device and plugged it in to make sure the wall socket is still live.
there is also a reset button on most power strips... it may have tripped.
Try those and let us know.
Robert
Sep 07, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension™ B110 PC Desktop Logo
406 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
