Question about Nexus NX32031 LCD TV
I need instructions on how to use the usb port
Multimedia HI-FI Speaker Systems model #SP710a setup
Computer speakers get their signal from the phone jack (maybe from USB port). They have a power cord (if USB powered connect to a USB port on your computer) to connect to a wall outlet.
Nov 15, 2013 | Computers & Internet
Apple mobile device usb drivers has malfunctioned and exceed the power limits of its hub port.
ok this is common with usb and high output devices try time machine or using two different ports
Feb 28, 2013 | Computers & Internet
Where is the USB 2.0 Port on a compaq Presario CQ60?
All four would be 2.0 if yours is a recent model Compaq. Your instructions should verify that
Dec 07, 2012 | Computers & Internet
I wish change parallel port to USB port. I have a ScanPrisa 640P Scanner and my computer use USB ports. What can I do ?
you will need an adapter like this one. But first make sure you have the current drivers available on the scanner before you connect the adapter. Refer this site for the drivers and instructions.
Jan 04, 2011 | Computers & Internet
I have transcend 2.5 usb store jet sata 120 gb hard drive which is not working , it only glows up the blue light on it
You need to plug it up to a USB 2.0 port not on a USB 1.1. There are many instructions to tell whether your USB is a 1 or 2 version but USB ports on the back usually are USB2 versions than the USB port on the front of your CPU.
The difference between both USB 1 and 2 for your Portable HDD is that USB 1 only uses 5volts power rather than the USB 2 which uses 8volts to properly revolce your SATA HDD.
Hope this helps. Thank you for using Fixya.
Jan 13, 2010 | Transcend USA 120GB Storejet 2.5" SATA -...
Dont know if I have the right cords specifically what is the connection process.
If you go to the Canon support site here you can downlod easy setup instructions. This page has some other manuals and user guides that may also be of use.
Here are the basic usb cable instructions:
Connect the USB Cable Correctly (i70 / i80 / iP90) Instructions to connect the USB Cable Correctly to the printer (i70 / i80 / iP90). Before connecting the cable
After confirming the printer and computer are turned off, connect them using the USB cable (sold separately).
Note: Below is an example of what a standard 'A to B' USB Cable looks like.
How to connect the USB cable
  • Plug the flat connector of the cable into the USB port of the computer.
    Note: If there are two or more USB ports in the computer, any available port may be used.
  • Plug the squarish connector of the cable into the USB cable receptacle of the printer.
<1> Computer's USB Port
<2> Printer's USB Cable Receptacle
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 20, 2009 | Canon PIXMA iP90 InkJet Printer
Need instructions for eGo portable hard drive. This shold ave come wit th purchase but did not.
there's no much need for instructions.
you just plug the hd into a USB port avaliable in your computer. the operating system should be able to recognize it a few seconds after you have plugged the hd into the usb port.
some hd may require for 2 usb to be connected to the computer for the computer to see it.. usually they come with a "y" usb cord. one goes to the hd and 2 usb type a cord go to 2 usb ports on the computer
to check to make sure the computer sees the hd. go into my computer and check if a removable storage device has appear.
also check your hd is on, some external hd may have switch to turn them on.
also check if your hd requires external power if it does it should come with a power connector that needs to be connected and plugged into the power outlet for it to work.
post your finding if you need more help.
Oct 14, 2008 | Computers & Internet
Bad USB Port in Camera
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Aug 18, 2008 | Kodak EasyShare DX7440 Digital Camera
Damaged usb port needs to be replaced on my HP Pavillion 513W computer. Need diagrams and step by step instructions
1-Shut down you pc .2-unplug the power cord.3-open the case .4-Find the usb wires trac them back to the board. 5-mark were the wires go with a marker.6-plug new usb port wires in.7-put the case back on pc.8-plug power cord in.9-turn on pc.10-plug your usb device in.
Jul 02, 2008 | Computers & Internet
Usb host controller
There are no drivers to install if you are not using Windows98 but are using an OS that is more recent. As to adding devices to your USB ports and those devices, such as a printer, needed to be attached to the port in a a proper sequence... usually after the software is installed and the software instructs you to do so. Same goes for the Scanner and the Mouse.
What to do? Uninstall the software for those devices, un-attach them from your system. Reboot and then install the software first and when instructed to do so attach the USB cable to a port. Do that for each device and reboot first if asked to before proceeding to the next device.
Regards,
Worldvet
May 21, 2008 | Soltek SL-75FRN2-L Motherboard
Nexus NX32031 LCD TV Logo
71 people viewed this question
Top Nexus Televison & Video Experts
Tom Chichester
Are you a Nexus Televison and Video Expert? Answer questions, earn points and help others
