Question about Dometic Rooftop RV Air Conditioner
Duo Therm 59516 Roof A/C clicks when adjusting temperature on thermostat but no blower comes on
  • 674 Answers
First make sure the breaker isn't tripped. Next use a voltmeter to check for power on the primary and secondary side of the contactor with it pulled in. If you have power then check the capacitor. If it looks swollen then it is bad or you can check it with a multimeter with the capacitor test function or take it to a heating and air supply and they can check it for you. If the capacitor is good and you have power, then use an ohmmeter to check the motor windings for continuity. Locate the common wire and connect one meter lead to it. Then connect the other lead to the start winding and read the meter and then connect that lead to the run winding and read the meter again. You should have some resistance on both. There will be more on the start winding than the run winding.
Posted on Sep 03, 2010
  • Dometic Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The first thing I would check is to see if you have power coming to the blower motor...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
306 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
