Question about Kenmore 36665 / 36669 Gas Kitchen Range
When the Bake or Broil buttons are pushed the clock flashes continuously and I am not able to turn on the oven.
  • 4,924 Answers
I think the issue is that it is unable to lock the door and this is the reason that will not start ..try to push the door in a little when you press the button to start the cycle ..or ..better before that ..check the locking mechanism to not be stuck ..move it a little ..and if it is greasy ..try to use something to clean it ..
Usually this kinda devices..have to complete a task before getting to the other ..in our case it is not starting until the door is locked..
If this isn't the case ..try to reset it ..for some models keepint the start button pressed will reset the job ..but you may take a look in the manual for a sure reset solution ..
Posted on Sep 03, 2010
I have a Kenmore 790.94479801 electric range. While using the Bake function, I noticed that the broiler element was on and the oven had gotten very hot. I hit the Stop button and noticed a small puff of...
When the broil function is off, check for continuity between the broiler relay output terminals. If there is no continuity, check for an external short. If there is continuity when the broiler is supposed to be off, you need to replace or repair the board.You can get your old board repaired at appliancetimers.com.
Mar 18, 2011 | Kenmore Kitchen Ranges
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
Why won't my oven go on bake
you have a bad clock board a stuck relay on the board.
get a new clock board.
Sep 03, 2009 | Whirlpool RBS275PD Electric Single Oven
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Kenmore 36665 / 36669 Gas Kitchen Range Logo
49 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
