Question about Peg Perego John Deere Gator HPX Ride on Toy
Motor on drivers side keeps cutting out after running for a few seconds.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
My impact driver when in reverse works fine but when in forward it will work for a few seconds then stop and keeps doing that. why?
I'd be looking for a defective forward/reverse switch, or a bad connection/wire on the forward side between the switch and the motor.
Jul 01, 2015 | Dewalt DW056 18V Heavy Duty 18V Cordless...
My dryer cuts on and then off I have by passed the thermal cutoff fuse and the door switch it will turn on when I plug it back in and run a few seconds and then cut off please help
does it run as long as you keep the start switch pushed then stop when you let go of button if so bad centrifugal switch in drive motor
Feb 20, 2015 | Dryers
Engine acts like it is out of gas keeps stalling i can turn it off for a few minutes will run for a mile or two then does it again
Vent valve has failed closed or cannister is clogged up. Have the evap system checked from the tank to the charcoal canister. If you need to drive to a mechanic, try driving with the gas cap loose.
Dec 16, 2017 | Hyundai Motor 1999 Elantra
Motor runs for a few seconds than cuts out. No cooling
The startup capacitor is weak and that makes the overload switch kick in. You can get a 1/4 hp to 1/3 hp 3 in 1 hard start relay to fix that from graingers, or 1stsourceparts. EZ instructions.
Mar 10, 2010 | Refrigerators
My drivers side headlamp motor keeps running after
Check this out. It is for older models but will probably set you in the right direction.
http://www.manxyanks.com/82-86%20Firebird%20headlight%20troubleshoot%20guide.pdf
Jun 11, 2009 | 2000 Pontiac Firebird
Drivers side wiper quit proper function. Driver side wiper only moves a few inches. Motor probably needs replacement. 99 chevy silverado p/u
some wiper arms fit over a splined pivot post. When you tighten the nut down, the splines cut into the wiper arm thus holding it tight and keeping it from slipping on the post.
You may just need to tighten the wiper arm down r replace the wiper arm. Does it have a cover that you can rotae up and expse the nut?
Apr 17, 2009 | 1999 Chevrolet Silverado 1500
Refrigerator quit working.
for what you are saying check your voltage check if your compressor or check if condenser working you need the fan to cool the compressor down
Apr 07, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Peg Perego John Deere Gator HPX Ride on Toy Logo
55 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
