Question about LG WM0642H Front Load
Won't drain during cycle, drain motor noise before stopping with OE drain error?
  • 1 more comment
  • swinghustle Sep 03, 2010
    Dear Heatman101, Thank you for the tip. I tried it but it still don't drain during cycle. I tried to open top and front panels of machine to check drain motor but could not reach to see it w/o detaching the drum from door panel. Is there a way to do this so if I have to replace the drain motor I can order the parts and do it myself. Appreciate if you can help me. Thanks again.
  • swinghustle Sep 04, 2010
    TY again for responding to my inquiry. I have the skematic diagram sent to me by the authorized parts dept of LG. Send me your email address to swinghustle@aol.com so I can send the diagram for you to analize. TY again and hope to hear from you soon.
  • Tom Shpak
    Tom Shpak Jun 20, 2011
    Can you post the diagram so I can look at is also?
  • LG Master
  • 43,501 Answers
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Posted on Sep 03, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 04, 2010
    I tried quickly to see if I could find an exploded view of your machine and it seems that the model is not coming up...
    If you check around you should be able to find a diagram of how that comes apart...that would be better then me misleading you...by trying to communicate that without being right there...
    But the bottom line is that many of those machine are not repair friendly... they are a pain in the **** to work on...
    heatman101
Shows OE on front panel. Wont able to get water and go further?
3e MOTOR RESTRICTION ERROR
Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
0e OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
May 19, 2015 | Dishwashers
Stopping during rinse cycle . not spinning. OE light
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 17, 2011 | LG Washing Machines
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
LG WM0642H Front Load Logo
2,061 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
