Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
The outside of the freezer section is hot to the touch when the motor/fan/whatever is running. Not enough heat to burn you, but surprisely hot nonetheless. As soon as the motor shuts off, the outside of the freezer section cools off. The inside of the freezer section is frigid and seems to be working fine. Any ideas? - Kim Gamble
  • Kenmore Master
  • 43,501 Answers
The heat is there to keep condensation down...it is nothing to worry about and normal operation...
heatman101
Posted on Sep 03, 2010
Section between refrigerator and freezer extremely hot.
Check your owners manual troubleshooting. See if you find an answer. Please be more specific. Sounds like it's "stuck" in defrost mode, since it uses electrical heating elements to make the freezer coils melt ice off, but only lasts long enough to remove the collected ice. I would guess the unit runs constantly, or cannot maintain temperature. If the defrost cycle is not working there is a timer not working, or relay, or somehow a very rare short in the defrost system.
Feb 18, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Aug 22, 2017 | Kenmore 14.8 cu. ft. / 419 liter Chest...
7 year old refridgerator not getting cold enough. Thawing in freezer. Should the condenser be hot/warm to the touch? Is there a re-set?
The condersor coil will be very warm to hot..not so much so it will burn you, yet very warm..the things that will make it very overly warm is if its clogged with dust or the condenser fan motor isnt running all the time the compressor is on. But it will normally be warm all the time the compressor is running..that heat is whats being removed from inside (the way refrigs. work is they remove the heat so when the heat is gone only cold is left)
GENE
Sep 04, 2011 | Kenmore 56983 Side by Side Refrigerator
Outside of freezer is hot to touch
Hi
If the unit was off for a while then more heat is inside the freezer after having it off for a while. That heat gets moved out to your condenser coil. Most freezers today don't have fans to force that heat to the outside air, they run that heat through the outer cabinet and it naturally travels to the cooler surrounding air. If there is no rear cover and no fan motor near that compressor this is how yours is designed. Just give it sometime and it should be fine. However it should be warm to the touch but not so hot you can't. And also depending on how long the freezer is running and how warm it is where the freezer is will affect how hot the outside is. The reason the outside of the freezer is hot is because that's how the freezer releases its heat from the refrigerant. The longer it runs or the harder it has to work the more heat it has to hive off. So unless the freezer is not cooling there is nothing to worry about.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | KitchenAid Superba KSRG25FK Side by Side...
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
The panel separating my side by side refrigerator from the freezer is hot - nearly to the point of burning. Kenmore model 10653606202
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | Whirlpool GS6SHAXLS Side by Side...
The outer jam of the freezer part of the refrigerator gets hot super hot why ?
you have the power adjust, summer controls, whatever its called for your model, and manufacture
but its normal, this is the YODA LOOP
or the MULLIAN htr.....
it is very normal for it to be hot to the touch, this is actually the heat that is being withdrawn from your box, in the older models, unless the paint is flaking i would not be overly concerned
Oct 02, 2009 | Refrigerators
Outside freezer is hot to the touch
Its normal, the heat is coming from the condenser which is integrated within the freezer cabinet and is completely out of sight.
Jul 10, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refridge
the condensor fan motor is bad!! Pretty soon the compressor will be too! Take the back cover off and put a fan blowing on the compressor this will help until the fan is replaced!!! Please!!! A solved rating for this one!! Its dead on
Oct 04, 2007 | GE Americana A3316ABS Top Freezer...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
118 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
