Question about Singer 2662
My machine is not catching the thread? what can i do ?
  • Charissa Natanauan
    Charissa Natanauan Sep 03, 2010
    which thread? the bobbin thread or the main thread?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Hello fellow seamstress; from a repair tech.
has this just started? I found out...the hard way...NOT to buy the Cheap thread. AND to keep my machine WELL cleaned.
Get out your Vacuum cleaner and vac the underside of your machine...use pointy nozzle. You will be amazed at how much fuzz has accumulated under there and in all other spots that the thread travels.
the user manual is avail for download at this site. i checked, it IS avail. i put in a note under the optional info area that said thread is catching. how can i solve it. when they email you, they MIGHT give more info on that to you.
(If this has been helpful, please rate my help++++Thanks for using FIXYA)
Posted on Sep 03, 2010
Bobbin is not catching thread
NOTE TO THE QUESTION. Bobbins do not catch thread. A hook underneath when you use the wheel to advance the machine will come and catch the under thread OR BOBBIN THREAD and pull it up.
Something common and I do it, wrong bobbin in the bottom thread. I have 2 sewing machines so put thread on both plastic and metal bobbins and then just grab the wrong machine bobbin.
If this is not the issue, take the machine apart and clean it well. Note the spots that you are to oil SPARINGLY.
Aug 30, 2014 | Sewing Machines
Shuttle hook not catching thread
it's possible that when you broke the needle it caused the machine to go out of time & only a sewing machine repair shop can retime the machine
Jan 24, 2012 | Singer Sewing Machines
Thread keeps on breaking whilst sewing
Could be one or a combination of the following factors:
old dry brittle thread
burr, or broken thread loop or damaged metal somewhere in the threading path that is catching the thread.
Top thread spool is catching, sometimes the thread will catch on the paper label on top of the spool or in the little knick on the spool, or if you have left a long loose loop of thread at the back and then its catching on the spool holder or some part of the machine and impeding the thread flow.
Bent, burred or blunt needle.
Needle in backwards
Incorrect threading up on top thread, maybe looped twice around take up lever?
Dirt or lint in the tension discs
I suggest you locate the manual and clean the machine, particularly the tension discs. Then oil and thread up from scratch with fresh needle, wind a new bobbin and check the thread path is correct.
If you still can't get a good stitch, then take it in for a service, tension device may be faulting.
Jun 16, 2011 | Janome Sewing Machines
THE SEWING THREAD WILL NOT CATCH THE BOBBIN THREAD
the needle is not catching the thread on the down stroke have you got enough thread out on the bobing for the needle to catch
Jul 22, 2010 | Elna Heirloom Edition 6005
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
Needle keeps breaking when embroidery unit is attached
Make sure the top thread is not catching and causing the breakage.
Sometimes the thread unwinds too fast and catches on the spool pin and sometimes there is a rough spot on the thread spool that catches the thread.
Thread nets will help eliminate the fast unwind (pooling) - you can find them at sewing machine dealers.
If the thread spool has a rough notch that is catching the thread, smooth it with an emery board or turn the spool so the thread feeds from the opposite end.
Mar 17, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Sep 07, 2009 | Singer 7436 - INGENUITY
I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Singer 2662 Logo
42 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
