Question about Samsung Refrigerators
I have a samsung RS2545SH and the freezer stays cool but the fridge wont get below 46 degrees. Its warm
  • 4,066 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Here is a diagram of your fridge parts with damper.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fM0612182-00005.png
Posted on Sep 03, 2010
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Have a 2 year old SAMSUNG RS2545SH Side by Side
This is going to be a problem with either the thermostat control or the compressor relay from the freezer to frigde, either way, you will need to call a service tech.
Jul 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator model rs2545sh/xaa. Freezer works good, but refer side does get cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
Temp in the refrige wont stay cold. frezer is fine. model name is rs2545sh
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung Refrigerators
RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Oct 18, 2009 | Samsung Refrigerators
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
127 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
