Question about Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator
Im having problems starting my 5793 ix2000 - Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator
Equivalence transistor tt2206
Equivalent Sanyo 2S?5793
Features : I(c) : 10A, V(cbo) : 1600V
1. High speed.
2. High breakdown voltage (Vcbo=1600V, Vceo=800V, Ic=10A, Pc=65W ).
3. High reliability (Adoption of HVP process).
4. Adoption of MBIT process.
TT2206 equivalent circuit is 2S?5793, TT2202, JL6920, 2SC5446
Dec 19, 2016 | Televison & Video
I have a generac ix2000 and has an overload light on with no AC power out. what do i need to check?
When you have a generator with a inverter in it you have to be careful of overloads an static electricity. More than likely one or more otf the MOSFETs has blown. An inverter is really a switching supply. Not very hard to replace parts but if you have spme skill with electronics take it apart an give it a go. If transistors have not blown you may find a blown fuse inside on circuit board. You will never find a schematic for any of these units. They are protected because the dealers pay to much for selling rights you cant hardly get them. But i would take it apart an see what you have. Or find a good electronics guy an ask him to check it
Jan 22, 2015 | Generac Inverter Ix2000 Gas Portable...
How do I fix this problem
You are drawing to much power and if your not drawing any power and that light is still on then the breakers in the gen are toast
Oct 12, 2014 | Generac iX2000 iX 2000 5793 Portable Power...
Generac ix 2000 how do I adjust fuel mixture
im not suure what you mean about "Bog" but this gen is only good to 1600 watts cont. (2000 peak) and it has a auto throttle so it will idle down all by itself when not loaded past say 40% of total load , but if you think your having fuel starve problems try all the simple things 1st Fuel filer (inside tank) clean carb and stuff like that , I do fix allot of small engines with a good strong dose of stp fuel treatment and i never need to take em apart
May 30, 2014 | Generac Ix2000 Portable Generator Inverter...
Generac troubleshooting
check that the over load switch is not seized of course then replace
Dec 28, 2017 | Electrical Supplies
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
Generac ix 2000 does not start. checked spark plug and it is good. oil good.
what a **** generator, worked for 100 hours and now wont start anymore.
did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
Apr 02, 2012 | Generac Power Systems Generac 5793 Ix 2000...
SoundCard
hello:
the windows 7 are the same driver for vista
Apr 26, 2009 | Computers & Internet
Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator Logo
364 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
richie46
Bill Boyd
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
