Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Image too Bright
When i try to take pics on daytime the pictures always turns out too bright. but when i use it on night it works just fine.
  • slashdotorg May 11, 2008
    i already set it on automatic but pictures still turns out too bright. u think the lens or shutter can be damaged?
  • Canon Master
  • 4,738 Answers
It sounds like you might be accidentally in Manual mode (little red camera with M by it).
Make sure the mode dial in the upper left corner is set to "Automatic" (select the little red camera "without" the M by it).
Posted on May 11, 2008
I have a vizio Vt470m....the picture has always been perfect. All of a sudden when picture shows scenes with very little light (dark scenes like at night, space, low light) the black color almost look
Either the TCON board or the LCD panel has failed. Start by replacing the TCON board. If the problem persists, the panel is bad and the cost to replace it would be too high.
Mar 22, 2014 | Vizio Televison & Video
Suddenly lost all picture. Left only with a bright screen.Tried changing channels and inputs, no difference. Turned set off for a while and turned it on. No picture, just a bright screen.
Hello, holl125,
I have problem like that too, Screen just turn white and bright.
Change the T-con board .
T-con board like above pic ( * just sample pic not real for that type).
You can purchase it on samsung or online market.
Thanks.
Mar 15, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
When i use my digicam during daytime, the picture seems so very bright that u can't even notice some picture of it...what should i do???
Digital cameras have White Balance settings which make the image brighter or work with certain light conditions.
Try to look for it in your camera settings and just put it in AUTO mode then enjoy taking pictures again.
Jan 28, 2011 | Canon PowerShot A420 Digital Camera
Can I program the automatic headlights to always shut off when the ignition is shut off - day or night?
I have a 1997 cadillac deville that has both 'daytime running lamps' when put into gear and 'twilight sentinel' which turns the headlamps and parking lamps on at night, and goes off during the day or when it is bright enough.
There is an adjustable delay for the twilight sentinel to turn the headlights off after the ignition key is removed and it is night time.
I had the 'daytime running lamps' installed on a 1990 Cadillac Deville that turns the headlamps only on when the ignition key is switched to on with an aftermarket module. The headlamps are about 70% or so as bright as the regular twiilight sentinel headlamps and parking lights and are designed to go on during the day.
The twilight sentinel overrides this feature when it gets dark outside.
I had the daytime running lamps installed by an auto electric shop that specializes in electrical systems, alarms, stereos, etc.
Does this help?
Jul 10, 2010 | 1998 Buick LeSabre
Unclear, too bright picture
First try defaulting your camera to factory settings. Go to the Menu, select Reset, press the right arrow, use your up or down arrow to find Reset again, then press Set. Your manual can be found at http://support.casio.com/pdf/001/EXS500_e.pdf
May 18, 2010 | Casio Exilim EX-S500 Digital Camera
Alero: low beams as bright as Daytime runners while brights work?
Look for the relay for the head lights,it may be bad.Also look for a bad ground.And check the bulbs too.
Nov 04, 2009 | 2003 Oldsmobile Alero
My pictures are too bright
How much do you know about your camera settings? Possibly you changed a setting. Try taking photos in full automatic mode.
May 02, 2008 | Canon PowerShot A520 Digital Camera
FD-88, viewing LCD in daylight, too bright
You're not doing anything wrong. Sometimes it's just hard to see to LCD. You could try turning down the brightness, or turning off the backlight, but that doesn't work very well either. There are sun shields for sale. I have a FD-88 also, And so far I've been able to see the screen ok in sunlight. But It's winter in Minnesota so the sun is low in the sky, and I can normally shade the screen with my body. Hope this helps.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
