Question about Coleman Powermate Powermate 5000W Generator
NO POWER OUTPUT- GENERATOR HAS NO BEEN USED IN ABOUT 5 YEARS. HELLP...STEVE
  • 12,061 Answers
Hi, well whenever any electronic Componentry is left un-powered, this can actually harm it. You see Capacitors, especially Electrolytic Capacitors, can & do, "dry out" and go into a high resistance state. They have a wet electrolyte inside them.
This is why, emergency equipment that is operated sporadically, is powered up and used, at least weekly, to prevent this from occurring. This also helps the Capacitors to "Re-form" & "Heal" as it's called. Also why we have a Stand by setting which keeps the power flowing through the circuit, but NOT actually powered ON.
OK, what to do, well the short answer is to replace the electronics module in the Generator. If this is NOT practicable, then replace ALL Electrolytic Capacitors, with same or better. This may return the unit to functionality.
Then of course you must attend to actually getting the motor to work. Once that's sorted out, you can at least troubleshoot the Electronic's side of the generator. help link below.
www.repairfaq.org/samnew/lmfaq.htm
You need to obtain a service manual or workshop manual for your unit. Contact them at the link below and ask them to supply you with a shop,service manual.
http://www.powermate.com/contact.php
Posted on Sep 03, 2010
Honda generator problems
Check the required oem specs for the speed. Make sure it's running at the correct rpm's otherwise if not you'll have a reduction in AC output at the receptacles.
Oct 18, 2017 | Electrical Supplies
Why do I not have any output?
Possible dirty contact or defective.
Jun 21, 2014 | Kipor 3000 Watt Generator
What is wrong with output?
Here is a PDF with troubleshooting tips and wiring diagrams: http://www.kiporpowersystems.com/pdf/service/IG3000~1.PDF
From Page 36 - If no AC power, first check for continuity between the terminals on the receptacle and the red and black wires going to the inverter module. See the wiring diagram. Check the contacts for discoloration or evidence of burning.
How much is the dc output
Al generators are different and will output different amps depending on the power rating and the power being used in any plugged in device. A simple calculation is to divide the power rating of your generator by the voltage produced to give the amps. So if you have a 2000 watt generator giving 12v DC, you will be drawing 166.6 amps maximum. If your plugged in device is using, say 50 watts, like a bulb, it will be drawing 4.16 amps.
May 13, 2014 | Electrical Supplies
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
My 10 years colman generator running ... I feed 240V to the main of the house, it used to work OK. But this time, most of my light bulb went bursted after 3-5 min. However, some are not... what has...
it sounds alot like it is producing alot more power than 120 volts per leg you should really only have plus or minus 10 percent of that voltage anymore will blow lights check voltage output with meter, if voltage is high may have problem with voltage regulator and it may need be replaced. I assume that not all of the lights in the house are on the same circuit therfore not on the same leg of the generator so is probably only one leg of generated power to high there for only blowing some of the lights
Oct 08, 2009 | Coleman Powermate Powermate 5000W...
Kohler magnum12 gas generator will not produce electric power
Plug an electric drill into your output power at the generator IF you have a plug at the generator. (Output power CB must be on.) IF not the closest point to the generator and then pull the drill switch and turn the drill in the reverse direction. That will flash the field. 1/2 inch drrill works best but with some effort a heavy duty 3/8 drill will work. Just rotate it quickly... when the generator starts working it will try to yank the drill from your grip so keep that in mind. (Trigger Sw on drill ON)
Kelly
Sep 02, 2009 | Kohler 12 kW Emergency Power System -...
JVC 36" TV will not power on and has a blinking power light...
Hi and welcome to FixYa,
Almost always, when an electronic device/equipment fails when powered with and by a generator, it is the power supply unit (PSU). The PSU circuitry expects a fairly constant/stable power source (120 or 220). The output of the generator tends to fluctuate especially under varying electrical load. Additionally, the AC frequency (60Hz) of the generator's output also tend to vary which most PSUs don't like. A noteworthy point to consider is that the generator is floating electrically, its output has no reference to earth/ground.
If you are considering a DIY (do-it-yourself), foremost to inspect would be the PSU particularly the regulator transistor and determine if it outputs +5 and ~+135 VDC. Another to check would be the HOT (horizontal output transistor). If when the TV was used powered by a generator, there was considerable vertical rolling, the vertical deflection IC would also be a suspect.
A friendly reminder, exercise caution when repairing TVs. It stores up EHV (extremely high voltage). It would be to your advantage to reference a service manual (JVC AV-36D303) or at the very least a schematic diagram with voltage readings.
Good luck and Thank you for using FixYa.
Jan 05, 2009 | JVC AV-36D303 36" TV
Coleman Powermate Powermate 5000W Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
