Question about KitchenAid Dishwashers
I took the washer arm off and now can't get it back on. Is there a trick?
    Genius:
  • 1,075 Answers
No not really it should just click back in and some dont click at all keep trying it will go back.adrian,,,,
Posted on Sep 03, 2010
Bernina 1010 hand wheel problem.
If your hand wheel would have a lock cam/washer probably you have fixed it upside down.
Dec 24, 2013 | Bernina Sewing Machines
How to take off windshield wiper arm
wiggle the arm back and forth when holding it up
Aug 20, 2012 | 1998 Honda Passport
Took my complete front axle out to replace cv joints and a rusted out lower suspension arm had new bushes pressed in to the axle mounting brackets.now on installing it back in i cant remember where the 4...
you are talking about the sway bar link. this also has a bolt and metal washers. i will show you a picture to make sure we are talking about the same thing, you will slide on a metal washer then a rubber one then in slides into arm from bottom or you can come down from the sway bar then slide another rubber washer and then a metal one next is a sleeve then a metal washer and then a rubber one, now it slides into control arm and then from bottom slide rubber then metal and the nut . hope this is helpful.johnjohn2_147.jpgjohnjohn2_174.gif
Sep 25, 2011 | 1990 Isuzu Trooper
In order to remove the P/S Gear Pitman Shaft Lower Seal where the Pitman arm is attached on a 1995 chevy G10 van , can the seal be removed from the outside by just removing the Pitman arm or does the gear...
Once you have the arm removed (use a puller made for that) You need to remove the c clip retainer. Many times you can loosely install the arm, put it back on the ground and with a catch pan under it, just quickly turn the wheel and pressure will drive the seals out. If that does not work, you can use long self tapping screws and put one into each side of the seal and pull it free. Most i've seen always have two seals separated by a steel flat washer. To re-install, you need to carefully drive the seal back in using a piece of pipe or anything that fits and does not damage it. I have special tools I made long ago to do that but the trick is to be careful not to get the seal too far in on any one side and to not damage it in any way. Likely someone makes an install tool. Make note of the order of the seals as you remove them and make a reference mark on the arm and shaft so you can get back together the same way it was.
Jun 25, 2010 | 1995 Chevrolet K1500
I have a Neptune series washer that keeps throwing the belt. I took off the back cover and found that it has been digging into the plastic back and has worn the belt down a little. Are there any tricks to...
Take the center bolt out of the pulley remove the large washer that fits into the pulley flip it over and re-install it and the pulley will cease to wobble.
Sep 21, 2009 | Washing Machines
The bin arm on my Uline Model 402 ice maker broke off. I have a replacement bin arm. I took off the front plate of the ice maker unit, but am unable to thread the bin arm all the way through the bin arm...
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
Jul 19, 2009 | U-Line Uline Origins Series...
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
F30 ERROR CODE
your dispenser motor arm is out of position. take the scews out of the back of the units top and remove top and you will see the dispenser arm out of position.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Arm head-shell spring contact unit removal
There is no trick to this. There is no easy way to repair that, unless you have the proper tools and experience. It sounds like your a novice, because of the questions you are asking.
Here is the issue you will come across...
You'll remove the collar, and find that there are 4 very thin wires soldered to the gold contacts. Those contacts have springs behind them. If they came off, or are damaged, that's it. Technics does not sell the parts for the tonearm individually. You will have to replace the entire tonearm. Soldering those thin wires back into their original position is extremely difficult. It's easier to replace the tonearm.
- DJ PRO LAB
www.DJPROLAB.com
May 04, 2008 | Technics SL-1200 Turntable
Dishwashers Logo
32 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
