Question about Canon P23-DHV Calculator
I am replacing the paper and can not get the paper to feed into the machine and I do not have my instruction. How can I get the instruction or find out how to replace the paper?
  • 8,197 Answers
You can get the manual on the link below.
http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/p23_dh_v#BrochuresAndManuals
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 03, 2010
I tried to replace the feeder of cartridge, then i open the mechanism. after complete the work, i saw paper should not properly feed. so how can i solve the problem ?
Make sure that there are not any paper fragments in the machine, this will cause the paper to either jam, or the paper not to feed properly. You should also take the paper that is in the machine out, fan it to separate it, and then put it in the machine. If that is to no avail, then try new paper, following the same instructions as mentioned above. You may also need to adjust the paper sizer mechanism as well.
Mar 07, 2011 | HP PSC 1410v All-in-One Printer
When recieving faxes on our canon laser class 2050p, the machine has a loud squeak
Your rollers will need to be replaces. Rollers feed the paper through the tray. You can find paper feed rollers for your device here:
http://www.precisionroller.com/paper-feed-components-for-canon-laser-class-2050p/products.html
They are very straight forward to install and instructions should be in your manual.
Mar 07, 2011 | Canon LASER CLASS 2050P
Does not want to feed paper at times
Erratic print feed is usually due to Quality of paper or the cleanliness of the rollers which pull the paper through the machine. You User/instruction manual has advice Paper quality and on how to clean the rollers. Make sure the machine is switched off before you attempt any internal cleaning
Feb 19, 2010 | HP Photosmart 2575 All-In-One InkJet...
How to load the paper into casio hr 100T . My son just came home with this old model. It has paper provided but no instructions. How do we get the paper to feed and in what directions does it need to be...
I have a casio HR-100 TM. After spending over an hour, and scouring the casio website which had an obscure spot that covered a totally different calculator!.... I found a slot in the back of the machine that when I folded the paper into an arrow, FINALLY went in! You may have to try a few times, but it will go in just keep holding down the feed button as you push and jiggle the paper.
Jun 20, 2009 | Canon P1-DHV Calculator
Printer paper loading
Just achieved, after trying for 2 days
Paper should drape over like toilet paper.
Cut sides to form a point in the middle.
Feed through back of machine. Paper will have a tendency to point upwards.
Guide though metal roller, then hit feed........should go through.
May 12, 2009 | Canon P1-DHV Calculator
Will not feed paper
Replace the paper feeding (PF) kit and the fuser. Instructions on how to do so maybe found on this manual.
Mar 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother dcp 7010 How to print envelopes
Use the manual feed slot to print or copy on labels,
envelopes or thicker paper.
Slide the paper guides to fit the paper
size.
Using both hands put the one sheet of
paper in the manual feed slot until you
feel the front edge of the paper touch the
paper feed roller.
Let go of the paper
when you feel the machine feed the
paper in a short distance.
May 16, 2008 | Office Equipment & Supplies
No paper feed
what is the printer brand and model#? also try making sure the paper is in far enough and isn't sticking, and the paper guide is tight
hope this helps
Apr 09, 2008 | Office Equipment & Supplies
Cannot find solution to how to replace paper for the Sharp UX-108 Fax machine
I must have an operation manual so Ican follow instruction and at the same time I will know what is the trouble.
Jan 17, 2008 | Sharp UX 108 Roll paper Thermal Fax
Loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Mar 19, 2007 | Canon P1-DHV Calculator
Canon P23-DHV Calculator Logo
93 people viewed this question
old marine
old marine
