Question about Emerson LC320EM9 32 in. LCD HDTV
A green line going down the middle of my screen. what does that mean?
I have the same problem on my laptop..It's the LCD crystals in the screen starting to die out, If it's just a strip or two then it will still wrk when they all go completely. Should get I would hope a min of three months to about 9 months before you lose 50% of screen. You may get lucky and it could last for year. There's not really much you can do about it, but to get it fixed would cost alot of money, I'd say buying a new laptop or computer would be a lot cheaper. Hope this helped.
Posted on Sep 24, 2010
47LD450 LCD tv has green line down middle of screen
Sorry, you can try reconnecting connectors on T-con board (small rectangle board at top center under metal shield)if you are lucky, but it is likely a panel failure. It won't hurt to watch it as it is, if it doesn't bother you
Feb 16, 2014 | LG 47LG50 47 in. LCD HDTV
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
There is a green line going down the middle of my screen. What does this mean?
My best answer there would be a defective display panel. It will not be worth repairing.....
May 07, 2010 | Toshiba 50HP66 50 in. Plasma Television
The screen on my laptop flickers colors and there are lines running through through middle red blue green ect.. it does work on an external monitor tho could this be the lcd inverter
Lines on the screen means the LCD is bad and needs to be replaced. The inverter just makes sure the lcd turns on. That wouldn't cause lines on the screen.
Nov 28, 2009 | Compaq Presario R3000 Notebook
Line down middle of the screen-resolution is different on sides
Computer parts can sit in warehouses and be on trucks for a long period of time. Unfortunately that means things get banged around. Sometimes they don't even work when they come out of the factory. I suggest exchanging the monitor for another one. It could also be your video card. Easiest way is to exchange it and it's free to exchange.
Jul 07, 2009 | LG Computers & Internet
I have an orange line down the middle of my screen
i have a thin green line down my computer screen how do i get it off ?
Jun 29, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Lines going across the screen
This means the convergeance is out of alignment. It is due to faulty components on the convergance board. There are capacitors that need to be replaced
Jun 05, 2009 | Hitachi 65F59 65" HDTV
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
Green line going down almost to the middle of the screen
Replace both convergence IC's STK392-110 X 2............T.
Nov 07, 2007 | JVC AV-48WP74 48" Rear Projection...
Emerson LC320EM9 32 in. LCD HDTV Logo
509 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
