Question about Whirlpool GEW9200L Electric Dryer
How di i get access to the heater element on the Whirlpool model GEQ9800LW0
  • 122 Answers
At the top of the lower small panel, use a putty knife to slide between the clips holding panel and pull panel out, bottom of panel has tabs holding to cabinet, you will see long heater box, element slides out
Posted on Sep 03, 2010
I have a whirlpool gold model number geq9800lw0. I need to know how the thermal fuse and cut off are wired with the heating element. Think I may have gotten some wires mixed up.
They are usually wired in series, the wire comes from the control to the thermal fuse, then from the fuse to the thermostat and then from the thermostat to the heating element, then from the heating element to the control.
Jun 06, 2017 | Whirlpool Dryers
How to chk heater element
You did not list a brand or model so I assume you already have access to the heater and the connecting wires. Disconnect the two wires at the heater terminals and (using a simple volt/ohm meter) check for continuity across (through) the element. Depending on the element and your meter, this should read 0 to 10 ohms. Most dyer elements will have temperature limiters (thermal discs) located nearby and at least one of the heater element wires will run to these thermostats. It's always a good idea to disconnect any wiring from these thermostats and check them for continuity also, especially on a Whirlpool product.
Aug 24, 2014 | Dryers
2 green flashes. hot water is blazing hot set at 120 degrees.have the energy smart unit model#ee2h50rd045v . what is wrong?
2 green flashes is 'High Water Temp.'
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Typical energy smart manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
3 flashes is Temperature Sensor failure.
4 flashes is Upper element
5 flashes is Lower element
Troubleshoot section says:
1) Make sure access doors and insulation are installed.
2) Check elements for resistance of 5-25 ohms (if element has a short in center of element, it might not trip breaker)
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) replace element and reset control system.
Buy ordinary 4500 Watt element from hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
4) I also suspect the self-diagnostic control box.
Manual says: Repair parts may be ordered through your plumber,
local distributor, home improvement center, or by calling
1-877-817-6750.
You need serial number, product number and model number from label on side of tank.
Jan 11, 2011 | Whirlpool Water Heaters
To check the elements hot water hearter stop heating.whirlpool electric
While the power is off to the water heater it's safe to remove the access panels. Once the elements are exposed a multimeter that is set on the Ohms can be used. The average reading of a good element is around 12 ohms. This can range a few ohms up or down. If you don't get a good reading the element will need to be replaced.
If the water heater has two elements the top element should be checked first. When a Whirlpool heater has two elements and the top goes out this will cause the water heater not to heat at all.
If both elements show they are good it would be recommended to contact the manufacturer. The technical support line for the Whirlpool water heaters is 1-877-817-6750.
Sep 02, 2010 | Whirlpool Water Heaters
Where can i get a heating element part # ao4415 for whirlpool dryer model # ler8648pw0. We removed the element and it appears to be burnt out.
HI. I have located a replacement heater assembly for your unit. Kindly, click the link below to access the purchase site.
CLICK HERE
You can order from the site link above.
Jan 17, 2010 | Whirlpool LER8648P Electric Dryer
How can i check to see if the defrost is working in my whirlpool refrigerator model number ET1CHMXKQ03. Initially water started leaking into the fridge from the freezer, i looked and saw everything iced...
you will need to access the heater in the rear area of the freezer compartment and disconnect the heater element and take a continuity test of the element,if this checks good,then in the same area is your defrost timer,unplug the heater from it and hook up a voltmeter and energize the defrost timer manually and see if you have a voltage there
Jan 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
How do you test dryer heating element on GEQ9800LW0
Ok maybe the heating element got old and brittle over time and finally gave up the ghost. But it may not be the element. It could be one of the safety Hi-limits have blown.READ MORE...
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Whirlpool GEQ9800L Electric Dryer
Whirlpool Dryer Model#GEQ9800LW0 will not get hot
Sounds like a heating element. Those can run pretty cheap and are not hard to replace.
Suzanne
Dec 11, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
