Question about Mitsubishi VS-70707 70" Rear Projection Television
I was told i need a deflection board for a vs-70707, would it be the terminal board or the main board assembly?
  • Mitsubishi Master
  • 8,457 Answers
This board are no longer in the market.Try website like Tvrepairworld.com might have a rebuild one.It part main board parts of the power unit.
Posted on Sep 03, 2010
Vartical line
Absence of horizontal scan. Check the deflection yoke, horizontal scan out capacitor at the main board, deflection yoke connector solder terminals at the main board for loose solder terminals. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 11, 2015 | Televison & Video
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
Our toddler pressed several buttons on our Mitsubishi VS-70707 rear projection tv, it powered off now we can't get it to power back on?
Very simple , you need to initialize you tv by pressing menu and input bottoms at the same time for 30 seconds until the picture coming up and select * intitialize* on the screen menu, and wait until is done and you done.
Dec 18, 2010 | Mitsubishi VS-70707 70" Rear Projection...
The internal fan wont run , it will run if you flick start the internal fan with your fingers. The fan motor was replaced to no avail, could it be the triac playing up. Ross
This is the main PCB diagram of the indoor unit of LG LS-K1830 model.526bf5a.jpg
  • Check the shown capacitor. Lift one leg then connect the test leads of the ohmmeter to the capacitor terminals. Do the same with the test leads in reverse. The pointer should deflect quickly to the right then slowly deflect back to the left on both instances. Otherwise the capacitor is bad and must be replaced with the same specifications.
  • If the capacitor is good or the problem still exist after the capacitor is replaced, check the voltage between the 2 inner terminals of the motor harness 4-pin connector as shown above. Voltage should read about 5 volts. If voltage is below 5V or not present, replace the indoor unit main board assembly.
  • Check the voltage between the labeled terminals of the 5-pin connector shown above. The voltage should be about 17 volts. If voltages is below 17 volts or not present, check the connection between the indoor and outdoor unit main boards. If connection is good, replace the outdoor unit main board.
Nov 26, 2009 | LG LS-K1830HL Heat Cool Mini Split Air...
My Mitsubishi vs-5061 isn't working properly. The red crosshair wont line up with the white ones going horizontally. The red is bowing. Causing most writting to have a double vision look. HELP!
Hi, this will occur when the convergence unit has failed . you will need to replace the convergence board in this unit in order to restore proper convergence functions. This is just below the optical assembly in the PCB main area next to the signal board and terminal block.
Jul 26, 2009 | Mitsubishi VS-50611 50" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Once power is off T.V. won't come back on
First CHECK IC700 PIN 20 (AC-OFF) FOR 0 VOLTS DC. IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Sep 05, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Vs-70707 dark on power up
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Aug 02, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi VS-70707 70" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
