Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
The water tank is getting really hot,steams come out the sides of it but no steam is coming out the bottom.
  • Euro-Pro Master
  • 43,501 Answers
It is clogged...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 25, 2010
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The water tank is getting really hot,steams come
The mop is clogged...
heatman101
I have a GENER8 steam mop i can not get it to steam it get hot but no steam, i have cleaned out the bottom foot but nothing can you help
There is probably a blockage preventing water from entering the steam generator.
Mostly with domestic steam equipment the water gravity feeds and it doesn't need much to stop the flow - often just a collapsed tube or a wayward blob of sealer.
Unfortunately to find the culprit the appliance will probably need partially dismantling.
Sep 23, 2016 | Vacuums
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Steam is coming out the water tank not the bottom
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not syeam grey pruple shark steam mop
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was having the same problem. No steam out the bottom. I took the whole thing apart and cleaned it...inside and the mop heads. I now get water to the heads but steam is still coming out the sides of the unit and leaking. I took it apart again and this time had my husband look at it. He found a tube with a spring in it...the spring had punctured the side of the tube and was leaking inside the machine! I am really upset by this as the machine never really worked right from the beginning but I really did not know it was not supposed to work this way. Now the machine is over a year old. I will be calling tomorrow and complaining but am not very optimistic that they will do anything and from what I have been reading will NEVER buy another one!
Sep 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam doesn't come out anymore when I pull the trigger. I think the water in the tank is getting hot, but when I pull the trigger, only a little water comes out. No steam
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
330 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
