Question about Samsung Digimax L730 Digital Camera
Samsung L730 Lense Stuck Open...
Okay. I got my Samsung L730 Digital Camera last Christmas (of 2007) and it worked fine. But then on March 13, 2008 I was looking through some of my pictures and I was zooming in on one of them and the screen just went completely blank...black. And the lens of the camera is still open. It's stuck/frozen. I tried turning it on but nothing happened. I tried charging it and nothing happened. I did not damage it in any way. Is there anything that I can do? Thanks in advance.
  • 1 more comment
  • EmmaP Jun 13, 2008
    I had the same problem.....i did some blog reading ....take the memory card out and the battery then put the battery back in and try turning it on it worked for me hope it helps!
  • fixasap Oct 21, 2008
    I had mine looked at and they said someone must of had their hand over the lens when turning it on. I really want my cam fixed, it's not even a yr old and I have so much to take pix of!!!! But I'm ready to chuck it at the wall...
  • jourdan rollo Oct 01, 2011
    pls tell me what is really happen
I have the same problem.. suddenly everything became blurry. mem card and battery out does nothing .. fiddle fiddle fiddle then all of a sudden it starts working correctly again - focussing clearly... took 1 or 2 photos then all of a sudden, it reverted back to its crappy state again. 3 days later its still in its crappy state of focus and seeing that a lot of people have the same problem with no real solution pisses me off. might as well chuck it in the bin now and save time ...
Posted on Oct 16, 2008
I too was having problems as my camera switched on but had a blurry screen and would not focus.
I took out the battery while switched on and carefully cleaned the lens and magically when i placed the battery back and and switched it on ...IT WORKED!!!!
thanks for your advice.....was going to throw the camera away!!!!!!!
THANK YOU
Posted on Aug 05, 2008
I had the same thing happen with my camera. Taking the battery out did not help. Using some aclochol (or other appropriate lens cleaner) to clean the lens did not help. Two days later it started working again. I can only assume we were at the beach that day and it got some moisture and or sand in it.
Posted on Jun 19, 2008
The same thing happened to me I took the memory card out and the battery ..put the battery back in and I was able to get it charging up which will hopefully close the lense once it is charged!..........Ill update soon!
Posted on Jun 13, 2008
I have the same problem. Tapping it does not help!! Any other suggestions?
Posted on May 18, 2008
    President:
  • 2,712 Answers
Try tapping a corner of the camera on your palm 2-3 times..it usually works..
Posted on May 11, 2008
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
Zoom lens will not open on L730 camera
hi,
its lance problem , its most probebly happens with them, you just well servise the lance , if you are a technition then try it at home otherewise contact authored person
Aug 31, 2009 | Samsung Digimax L730 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
My samsung digital L730 wont turn on
Just fixed mine, if the lens is out that's the problem we had, it was jammed and not allowing it to switch on, we gently pushed it back in, then switched on, the lens came out a bit then jammed, pushed it in again & kept doing it until it cleared the blockage.
Works fine now!
Hope it works for yo
Jan 03, 2009 | Samsung Digimax L730 Digital Camera
My samsung L730 lense is stuck
i have the same problem with these camera. to get it fixed just take out the battery wait for a few sec and put the battery back on, then switch the camera on. for the lens just gently move/force the lens to open, then turn off the camera wait for a few seconds then turn on the camera back on see what happens. and if still persist keep doing it till gets back to normal.
this sometimes happens to my camera from time to time i think it just its wear and tear.
one more problem with this camera is that it'll go blurr, just do the basic turn off or take out the battery wait a few sec and then turn it back on.
hope this will help u.
Nov 08, 2008 | Samsung Digimax L730 Digital Camera
I encountered this issue today while taking a photo of my dog she licked the lens... the LCD screen went all blurry and I was unable to take any photos. The thing kept beeping at me and I was about to throw it in the bin until I had a good look at the lens. As there was a picture coming through on the LCD I knew it wasn't completely stuffed however as the camera couldn't focus an image it gives the unhelpful beeps which apparently translates to clean the lens! So i gave it a clean and presto it was fixed!
Just be careful when u clean it make sure u don't scratch the lens with rough material or use chemicals. Hope it works.
Feb 17, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
189 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
