Question about Briggs & Stratton Garden
I have oil blowing out my exhaust and smoking
  • 43,501 Answers
The rings or the head gasket have gone...either way you have major engine problems...
heatman101
Posted on Sep 03, 2010
My motor is blowing oil straight out the exhaust; What is wrong?
check the oil level in the sump
the indications are that the oil ring cannot handle the oil load
possible that the fuel tank has drained into the sump through a faulty float needle and seat
Sep 27, 2015 | Garden
Why is my 2000 kia sephia blowing blue smoke from the tailpipe. it has 86,000 miles. the check oil warning light is on even though the dipstick reads full.
The most common cause of blue exhaust smoke is oil leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. This is most frequently seen in older or high mileage cars with worn seals and gaskets. It only requires a very small amount of oil leaking into the cylinders to cause excessive blue exhaust smoke.
Blue exhaust smoke only at start-up can indicate worn piston seals or damaged or worn valve guides which may also cause a rattling noise. An external engine oil leak can drip onto hot engine and exhaust parts causing what appears to be blue exhaust smoke. Other possible causes of blue exhaust smoke include: piston wear, worn valve seals, a dirty or non-functioning PCV valve, worn piston rings, an intake manifold gasket leak, worn engine oil seals and possibly even head gasket failure.
Oil leaking into the cylinders can cause a rough idle, misfire and fouled spark plugs. In addition, a reduction in power and oil loss can be indicators that the blue exhaust smoke is caused by an internal engine oil leak. Internal engine oil leaks can also allow fuel to mix with the oil in the crankcase which will degrade the oil and prevent it from adequately protecting the engine.
Operating a car with a severely dirty oil filter, air filter or improperly functioning PCV valve can also sometimes result in engine oil blow-by, oil loss and blue exhaust smoke. Periodically checking the engine oil level with the oil dip stick will indicate if there is excessive oil consumption. Higher viscosity engine oil can sometimes temporarily reduce the amount of blow-by; however, this is not generally recommended. Excessive blue exhaust smoke indicates a possible internal engine oil leak that should be inspected by an ASE certified mechanic.
Dec 08, 2014 | 2000 Kia Sephia
1984 honda big red smoking out the exhaust littel oil coming out tho also it has the wrong carb on it the carb come off a honda atc 200x
If it is black smoke, it could be running rich and the correct carb will fix that. If it is blue smoke, then it is burning oil.
Apr 10, 2014 | Honda 84 Atc200 Big Red 200 Engine Stator...
Engine is running to too rich ie: blows a lot of smoke and some oil from exhaust
If its blowing oil out the exhaust then that is most likely where your smoke is coming from, not from running rich.
It would also help to know something about the motorcycle as they are not all created equal.
Sep 07, 2011 | Yamaha Ness Signature Series Vegas...
Are bike is having a little smoke coming from the exhust pipe we think it might be the antifreez we just moved from florida our manual is packed away just need alittle advice
is it blue coming from the exhaust
is it a 2 stroke if its a 2 stroke blowing blue smoke its quite normal if its blowing to much your rings might need replacing keep an eye on the ((oil level))
if its a 4 stroke and its blowing blue smoke from the exhaust keep an eye on the ((oil level)) the rings might need replacing if its burning lots of oil and blowing blue smoke your rings do need replcing
hope this helps
Mar 02, 2011 | Geovision GV-650 BNC (GV6504) Video...
What are the possible causes of smoking from the exhaust? My car is a Toyota AE 11O, year 2000
what colour smoke ?? blue smoke is oil ,worn rings or valve guides ,or oil seeping into cylinder where oil passes through head gasket to lubricate cam ,white smoke is water ,head gasket ? black smoke is excess fuel
Sep 03, 2010 | 1988 Toyota Corolla 4 Door
White smoke blowing out of exhaust?
black smoke is fuel white smoke is oil. change your spark plugs to a hotter plug and run with some hpr 50 engine oil or somrthing nice and thick
Oct 11, 2009 | 1996 Ford Thunderbird LX
Garden Logo
381 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
