Question about Whirlpool Calypso GVW9959K Top Load Washer
New calypso today. when the clothes are done the are soaking wet
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 03, 2010
Calypso washer is unable to get through cycles without start/stopping every 30-45sec. I have run the diagnostic test pushing (Soak then Soil Level, Soak then Soil Level) it counts down from 99-0 going...
after and hour off will it make it through the cycle? if so the motor could be over heating and shutting down. if not look and see if the pump turns freely and if there is an idler pully make sure it turns freely. check between tubs outer and inner for any sock or piece of clothing that could have went over the tub on a large lode and causing a resistance.check for a pinched off drain hose which will not allow it to drain. it has to drain to spin. or it will over heat pump. could be something caught in pump. try not to get wet,. done that alot when i had my business.
May 26, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Water does not wet clothes on wash and even on soak.
Machine is not taking enough water in. Check the level control pressure switch. Could be set to too low a pressure
Jun 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
Clothes are soaking wet after done
You may need a belt or a pump. Call sears they will help more.
Oct 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Calypso fails to remove excess water from washed clothings
There are two separate motors, one for the tub and one for the pump. They are both controlled by the motor controller board. Since you say the water drains, the pump appears to be working but since you say the clothes are wet, the spin probably didn't happen. I would suspect the drive motor or the wiring for that motor. There are procedures on the web for testing the wiring and motor windings. Good luck. There is also a pdf diagnostics/test document available. http://www.affordableappliance.com/Download%20Folder/Calypso%20Washer%20Service%20Manual.pdf
Good Luck!
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Why does my brand new ( just got it today) kenmore washing machine stop in the middle of the cycle?? the clothes are still soaking wet!!!
Contact the place you bought it. Dont even try to guess a new unit should work without question. There is a year warrenty. Just return it.
Jul 17, 2009 | Washing Machines
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Washer
I'm in the process of tearing apart my Calypso, Ugh. I found the diagnostic chart inside the machine. 5L is actually 'SL' which means suds lock, and can be an indicator of a failed pump, an extra heavy load, excessive detergent, or excessive suds. Corrective action is to press Stop/Cancel to clear the display.
Mar 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
