Question about Microwave Ovens
Will not restart or respond to reset clocks or lights wont work nothing works what should we do
  • 117 Answers
Don't do nothing at all??
If nothing works or no lights come on, try to change the outlet if not working replace the fuse of the MW
Posted on May 11, 2008
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
I have a GE JES831WB 001 microwave that I'd love to fix. The light, clock & timer are working, but that's all - no fan nor heating. Any suggestions?
The door switches are often a problem, one or two are probably defective which would cause the symptoms that you are describing.
Apr 05, 2012 | Microwave Ovens
Model # MH7149XFQ - 0. Nothing works. No light when you open the door. The control pad does not respond. The light under the microwave does not work. The clock display shows the digital clock but the clock...
1. Go check your breaker box. Find the one for this outlet, reset. Or just reset every one if U cannot figure that out. 2. if that does not do it..... The ck the Outlet w/ a proper tester (cheap @ builders supply, just a plug in tester w/ lite for volts.... too easy. 3. If neither of these work, find the fuse for the microwave & replace. If not qualified, hire or ask someone who is.... 4. none of these work..... time to buy a new one. gettocar
Aug 14, 2011 | Whirlpool MH7140XF Microwave Oven
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
Apr 03, 2011 | Samsung MC5694 Microwave Oven
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
The display lights are all solid and nothing happens when you press on the keys. I have a GE Sensor Microwave. I bought it in September of this year. Came home from work one day, went to heat something up...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may have a failed keypad.
Dec 11, 2008 | Microwave Ovens
Microwave not working
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
106 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
