Question about Garden
Stihl fc 55 won't start - Garden
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: Stihl FS 55 will not start
After trying to start several times, remove the spark plug and see if it is "wet" If it is you are flooding it. Do not pull the rope more than 3 or 4 times with the choke closed, whether it "pops" or not open the choke half way after the 4th pull and make sure you have the throttle trigger squeezed to give it gas
Posted on Sep 16, 2009
qumozheklj
  • 23 Answers
SOURCE: Where can I download stihl fs 55 repair manual or stihl fs 55 service manual?
stihl fs 55 repair manual Complete Service / Repair manual , Diagrams / photos , Circuit diagrams , Wiring diagrams , Schematics , Parts List ,etc.
http://autopartsrepairstore.com/stihl-fs-55-repair-manual-stihl-fs-55-service-manual/
Posted on Apr 09, 2016
Gas cap for a Stihl FC 44 edger
contact any Stihl dealer .
Aug 04, 2017 | Stihl Garden
Stihl FC 72 Edger. The little plastic switch is preventing the pull cord from spinning. How do I fix it?
BUT THE PLASTIC part is looking good ? also " If you can turn it easily ofcourse " its looking 100% the spring looks good but how are the cams on the choirturd ? or the movement of start spring? there is i think the problem
Aug 09, 2015 | Stihl Garden
Why won't my Stihl FC 55 edger run?
First remove the module and clean the mounting areas to be sure the module has a good ground. Leave the ground wire off the module and run the unit. If it runs fine then you will have to kill the motor by pulling the spark plug or choking it down. If it runs fine reattach the ground wire and run again. If ran good without wire but not with then the switch is bad. If wont run good either way then likely a module.
Aug 05, 2014 | Stihl Fc-mm Edger Kit Sleeve Mm55 55 Yard...
Stihl fc 75 edger switch
nothing you can do but replace the switch assembly. depending on its age it might be covered by warranty..
Feb 08, 2013 | Stihl Garden
Stihl MM 55 won't run/start
You will have to have extremely clean fuel with stihl carbs. As the orifices are extremely small some are so small you can barely get human hair through them. So make sure you are using correct mixture if it says 50-1 u better make sure you use 50-1. Also make sure the can has no trash of any kind. And main thing make sure the fuel filter is in place and not at all damaged.
Aug 05, 2017 | Stihl Garden
Stihl fc 44 edger blade not moving when I press the throttle
check both where the shaft attaches to the motor and also to the guard housing. they sometime vibrate loose and need to slide back in place. also the clutch can wear out.. try the shafts first...
Sep 07, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
STIHL FC 90
needle nose pliers and a lot of patience.. best to disconect the fuel lines from the carb, remove the tank and remove the fuel line and gromit from the tank. filter come out with it. replace it then work in reverse till its back together.
Aug 11, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
STIHL BRUSHCUTTER VERY HARD TO STARTAND WON
Could be a fueling issue, check fuel lined and fuel tank vent. Vents can become damaged and create a vaccum in the fuel tank, stopping the carb from drawing up fuel from the tank.
Jun 07, 2012 | Stihl String Trimmer Brushcutter Service...
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
