Question about Marantz SR6001
When the power goes off, and back on, a majority of the time there is a rapid clicking noise where the power cord goes into the back of the reciever. If i unplug it, or alter the direction of the plug, sometimes it stops. What makes the noise, and can i replace a part? I dont want to send it back in.
    Sergeant:
  • 334 Answers
It could be that you have a loose fitting power supply cord. Try replacing it and make sure it's pushed in FIRMLY. Also, blow away any dust or debris that maybe in the connector causing a poor connection. If it's actually sounding like it's inside the metal chasis of the amp. DO NOT TAKE ANY RISKS and un plug it, you will then HAVE TO tak it in...unles your a trained electronics guru type.
Good Luck
Posted on Sep 03, 2010
My 2007 Altima makes a rapid clicking noise when the car is in gear and the brakes are keeping the car at a stand still. It goes away when placed in park or neutral. The noise seems to be coming from the...
I would look more towards the belt tensioner. Look at it when idling, Then when some one puts it in gear. If it is jumping, which they do. See if it is coinciding with the clicking.
Feb 24, 2016 | Cars & Trucks
TV will not turn on-- clicking noise in the back
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Nov 15, 2007 | Panasonic PT-50LC13 50" Rear Projection...
How do you wake up a controller that is asleep?
The majority of controllers have a sleep timer. If the chair is on for a specific time period without use, it turns itself off, or, goes into a sleep mode. The chair is in a sleep mode when the operator tries the move forward and the chair does not move and lights on the controller blink rapidly.
To solve this, simply turn off chair, wait 10-30 seconds and turn chair back on. You should be able to operate as normal.
May 31, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
Apr 22, 2014 | Whirlpool Cooktops
When i turn on, the green light comes on then goes out,why
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 28, 2012 | Computers & Internet
TV wont turn on. I unplug the power cord and here a clicking noise inside the back of the TV. Plug it back in and try turning it on but still nothing. I try the power button on the TV as well as trying...
Very good TV. Since this is LCD there's not much that goes wrong with them except their internal power source. You will have to get it serviced. It is not something you can do without the expertise.
Jan 23, 2011 | Dell W2600 26 in. LCD Television
Loud clicking noise when turn on printer
I would check wherever possible for foreign objects in the printer. Failing that, a partial reset is available for your PSC 2410:
A partial reset can be done by:
1) Unplugging the power cord (you are already there!)
2) Press and hold the (#) key and (3) key while plugging the unit back in
Dec 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Power cuts off periodicly
Maybe. Try a larger guage extension cord.
Jun 11, 2009 | Sony STR-DG820 Receiver
Printer says low level color ink fitted new ink printed ok at first but still said low ink order now and will not let me print or scan
Dear customer,
The most common solution is to follow the steps as follows
1. unplug the power cord
2. press and hold down the <ON/OFF> button and reconnect the power cord
3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
4. Display LED show "0" press the <+> button 1 time Display LED show "1"
5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
7. Push down on the end of the black cartridge. A clicking noise will be heard.
8. Slide the cartridge out of the holder towards you.
9. Push down on the end of the color cartridge. A clicking noise will be heard.
10. Slide the cartridge out of the holder towards you.
11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
12. Reconnect the power cord.
13. Turn on the printer.
14. Open the cover. The carriage that holds the ink will move to the left hand side.
15. Place the black cartridge in the bottom of the printer.
16. Slide the black cartridge back until is cannot go back any further.
17. Push up on the end of the black cartridge, a clicking noise should
be heard.
18. Place the color cartridge in the bottom of the printer.
19 Slide the color cartridge back until is cannot go back any further.
20. Push up on the end of the color cartridge, a clicking noise should
be heard.
hope its udeful. thank you.
Jul 09, 2008 | Office Equipment & Supplies
Power on and yet picture flicks and powers it's self off (over and over again)
First it's not just Philips, they all are making TV to only last a few years now, they are not made to last, thats how they make money by selling you something you will have to replace in just a few short years. As far as your problem, you may have a cold solder joint somewhere, do you have a 25/35 watt soldering iron? if so try soldering pins on the regulator IC the vertical IC the horz output transistor and drive transformer and the flyback, in fact solder just about as much as you can, spend some time in there soldering. Dont forget to ubplug the set and stay away from the high voltage anode connected to the picture tube, it can still hold a charge even if the set is unplugged, do not try to take it off. Hope this helps!
Sep 27, 2007 | Philips 27PT543S 27" TV
Marantz SR6001 Logo
145 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
