Question about Garden
Bit frozen in chuck cannot loosen is there a release or just using two wrenches
  • 43,501 Answers
WD-40 and two wrenches has always worked for me...
heatman101
Posted on Sep 03, 2010
Screwdriver bit is stuck in chuck
Hello, W/D here.
Spray some penetrating oil in the chuck alongside the bit. Work the chuck back and forth, attempting to get a little slack in the chuck. Rapping along the side of the chuck with a plastic hammer will help, but use a regular hammer if you don't have a plastic one, just don't hit quite as hard. Tap the bit to loosen it, and continue to tap along the chuck, working back to the bit every so often. Eventually, the bit will release, and you have already lubricated the jaws of the chuck. Operate the chuck fully once the bit is released to free up the jaws. It will work like new.
Best regards, --W/D--
Mar 07, 2011 | Garden
How do i remove the bit from the drill
There are to parts to the chuck. You hold the ring at the edge of the chuck from turning, and then you turn the part after that, ccw to release.
Jan 30, 2011 | Dewalt 18 Volt Compact Drill Kit
Ds14dmr cannot get the chuck screw to release I am aware it is left handed thread
If the chuck is too tight to get the bit out you can either put a glove on one hand grab the chuck and run the drill in the reverse direction or if that will not work use vise grips or a small pipe wrench on the chuck to loosen it but be sure to tape the pipe wrench or vise grips with a thin piece of duct tape so you don't gouge the drill chuck.
Jun 30, 2010 | Hitachi DS14DMR 14.4V 1/2" Driver Drill
Can't release drill bit from Buffalo cordless drill
May 26, 2010 | Buffalo Tools COCD24 24 Volt Cordless...
Bit is stuck / jammed. Can't seem to loosen. Any ideas on how to fix?
May 23, 2010 | Black & Decker BD12PSK 12-Volt Smart...
I am trying to use a portable rotary tool but i can't remove the drill bit that's already on it, there isn't a reverse button on the tool so i am at a loss for how to remove it. can you help me?
You have a wrench that fits the chuck and a stop button that locks the shaft, loosen that chuck up and pull out the old bit, if it is frozen or rusted, try poking it against something solid, make it go in to break it loose, then pull out the bit. If that doesn't work, soak it in blaster or some other penetrating oil, then try the same again. Hope this helps.
May 23, 2010 | Craftsman Tools & Hardware - Others
I have a broken drill bit stuck in a B&D BD154R chuck It is broken off low down so I can't get a pair of pliers on it. What can I do?
If it won't fall out with the chuck fully open, you'll have to remove the chuck. use an allen wrench larger than the jammed bit and lock it into the chuck. Hit the allen wrench with a soft hammer to loosen the chuck. Remove chuck completely and push the bit out from the bottom.
Mar 09, 2010 | Garden
Broken Makita Drill 6408k chuck
separate the housing and remove the gear assembly and chuck ....see if you can use a open end wrench on the shaft and locking pliers on the chuck body
Sep 17, 2009 | Makita 6408K 3/8" Variable Speed,...
I can't loosen the part where the drill bit goes in. It's stuck!
Try using a large wrench to turn the chuck. It may loosen enough to release the bit
Apr 18, 2009 | Black & Decker 18 Volt Cordless Drill...
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
