Question about Dometic Rooftop RV Air Conditioner
Why do I have red liquid coming from the condensate drain?
    Master:
    Sergeant:
  • 449 Answers
Sound like a rusty condensate pan
Posted on Sep 03, 2010
Water is coming out of indoor mini split. At present time high humidity. Fujitsu machine. Filters are clean, serviced by tech.
It probably has a blocked drain. A bit of liquid bleach into the condensate tray and let it sit for a while before running the air con to flush it down usually does the trick. Otherwise you may have to insert a tube into the drain and blow it clear.
Oct 16, 2017 | Fujitsu Heating & Cooling
Condensation
Condensation is the change in matter of a substance to a denser phase, such as a gas (or vapor) to a liquid.[1] Condensation commonly occurs when a vapor is cooled to a liquid, but can also occur if a vapor is compressed (i.e., pressure on it increased) into a liquid, or undergoes a combination of cooling and compression. Liquid which has been condensed from a vapor is called condensate. A device or unit used to condense vapors into liquid is called a condenser. Condensers are used in heat exchangers which have various designs, and come in many sizes ranging from rather small (hand-held) to very large.
The water seen on the outside of a cold glass on a hot day is an example of condensation.
Dec 09, 2007 | Canon EOS-1D Mark II Digital Camera
My nissan quest 95 is leaking water. It seems is coming from around the filter. Need help please
Dear Helen,
Which filter? You have the air filter, the oil filter, and the cabin filter.
If it is coming out near the air filter or the oil filter, I should suspect a leaking heater or radiator hose.
A pressure tester for the radiator will help you find those leaks.
If it is near the cabin filter, it should be the drain tube for the air conditioner condenser, which is normal to leak when the air conditioning is running.
Try to catch some of the water that is leaking and see which fluid it is.
Air conditioner condensation water is clear, it even looks drinkable.
Anti-freeze/coolant liquid is colored blue, green, red, or yellow, (it depends on the brand) and has a distinct sweet smell and taste. No, I am not recommending you should taste it.
God bless your efforts.
Sep 04, 2015 | Nissan Cars & Trucks
Clear liquid is leaking from the bottom of my 2009 sentra
There is little I can think of that is going to be a clear liquid in your car. The only things that I can think of 1. Condensation coming from the drain of your A/C unit(most likely), 2. If it is a small amount and it is coming out of the tail pipe, it is water. The catalytic converter turns most of the unburned gas from your engine into water.
Automatic transmission fluid is RED, Antifreeze is Green in Nissan products, Brake fluid will be a semi clear liquid with a brownish hue to it. Manual transmissions use gear oil which is a golden color. Engine oil, depending on how well the car has been maintained, will be a light goldish to a black.
I hope I have answered your question.
Aug 06, 2011 | 2002 Nissan Sentra
White liquid in gearbox
The liquid is emulsified water. Condensation in the gearbox, riding in creeks or a from high pressure car wash is where the water usually comes from. The gears emulsify the water into the oil thus turning the oil whitish. Just drain the oil then put in fresh oil, ride for a mile or two then change the oil again. No real harm has been done to the engine. Please rate my answer. Thanks!
Mar 28, 2011 | 2000 Yamaha DT 125 R
Strange odor coming from underneath the refrigerator when it goes into defrost
It is likely that some milk or some bloody meat (or other stinky liquid type substances) have leaked in the refrigerator, went through the drain tube and into the condensation pan.It won't evaporate, so it begins to decompose and stink...usually at the most inopportune times.
Most condensation pans can be removed to be cleaned but can be tricky to get out. Good Luck!
Mar 05, 2011 | Whirlpool Refrigerators
Have coolant leeking on passanger side windshield fogs up even with the car sitting in the drive way. I believe the heater core is located on the passanger side back by the fire wall just would like to...
Hmmm.... That might a condensation wter from ur A/C or as u have said ur coolant. The liquid coming out from ur a/c and heater housing, the problem would be the DRAiN hose thats been blocked! Look down in that area where this liquid coming from, a HOSE will be in there and going thru the floor area, either the drain hose is blocked or it dislocated itslf and didn't pass thru the floor drainage hole! Check on that! Taah!
Nov 17, 2010 | 1999 Saturn SL
Water dripping right front underneath
Is what the liquid plain water or coolant (water mixed with antifreeze). touch and smell the liquid, no smell = water, antifreeze smell and oily feel = coolant.
If plain water, could be Air Condition condensation dripping from condensation drain which is normal. (this drain is usually located near the center of the vehicle).
If coolant, could be leak(s) from: radiator, radiator hose, heater hose, water pump, engine freeze plug. A coolant system pressure test should show what is leaking.
Oct 06, 2010 | 2005 Hyundai Santa Fe
Water from the ac is leaking into passenger area
TOUCH DOWN with leaky ac into passenger compartment solved!
Discovered on left side of firewall of trailblazer a series of ac hoses leading into compartment. Bottom left area are 4 hoses and one drain portal. I removed drain stem 4" long and compress bottom of portal with finger and condensation started pouring out. A total of 2 quarts of clear liquid condensation came pouring out. Tested ac afterwards and drain portal is flowing freely underneath vehicle.
Jun 24, 2010 | 2004 Chevrolet TrailBlazer
2004 Chevrolet Tahoe-front passenger side floor is wet
Check the heater core unit located underneath the dashboard on the passenger side of the vehicle. Even though your car's antifreeze is red, it may appear to be clear when there is only a small amount present. Was the liquid in the vehicle sticky and have any smell to it?
Aug 02, 2009 | 2004 Chevrolet Tahoe
Dometic Rooftop RV Air Conditioner Logo
81 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
