Question about Microwave Ovens
GE microwave JES1142SJ When plugged in power is on, but control panel does not work. Bought new today. We did get the clock set initially,,then it stared going off on it's own. Unplugged it to try and reset now contol panel will not work.
    Genius:
  • 1,073 Answers
Bad control, smart board is bad
Posted on May 11, 2008
Start botton on touchpad not working
Try unplugging unit for 5 minutes then plug in and clear cancel. Re-set clock and tryto program. If this does not work, call service tech. A quilified tech will open up & test touch panel and control board.
Mar 27, 2012 | GE JES1142SJ Microwave Oven
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
F3 Message on microwave
Hello
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3. An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
Repeat Step 5 for the other membrane that is on the control board.
Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
Peel the wax backing off of the top membrane, then place it on the control board.
Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
Plug the microwave back into the power outlet and reset the clock.
Oct 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE model JES1142 won't start nor even light up when plugged in.
I would remove the outter shell and check the glass fuse inside next to the power converter.
Nov 10, 2010 | GE JES1142SJ Microwave Oven
Willl not come on
not a lot to go on here?? try the plug fuse, if its getting power then its inside the microwave just dont try opening it up, there is at least 1000 volts inside this unit, tuch the wrong place and its a set of wings for you
1000 volts kills out right!!!
Oct 20, 2009 | GE JES1142SJ Microwave Oven
Microwave shut off
try to checked the fuse if its blown.and replace a new one,check also the power cord.
Jul 05, 2009 | General Electric Microwave Oven
I ran the microwave with nothing in the oven (obviously by mistake). Now it won't heat the food. Timer, clock, etc works. Is there a simple part that I can replace to solve this problem or have I killed...
You can replace the magnetron tube and , the heating will be restored. this is repairable.
Most magnetron tubes will run in the 120 to 140 dollar range.
Jun 19, 2009 | GE JES1142SJ Microwave Oven
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Control panel locked
A "hard reset" may work. Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
210 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
