Question about Fujitsu Siemens (MHV2060AH) 60 GB Hard Drive
Adding mhv2060ah ide drive externally with usb connection
Have a USB connector that is 'y' ed at one end with a thinner and thicker lead. Plugged into a USB port, computer recognized drive and installed drivers but it doesn't show on my list of drives.
Would appreciate help!! I know that I need to partition and format but can't figure it out. Running XP
Thanks!
Harvey
Dsvdsdbsd
Posted on Nov 27, 2008
How do I read a barracuda 7200.12 1 TB drive? I need to get data off of it, not boot on it
Hi
The easiest way that I have found is to get a kit that allows you to power the drive from a separate wall socket and connect a data cable from the drive to a USB socket on the computer. Such a kit usually consists of four components:
A mains lead - wall socket to black box transformer
The black box transformer - has outlet 4 pin molar for IDE drives
A USB cable ending in unit for connecting to an IDE drive or SATA cable
A SATA cable for connecting to the SATA drive (your Barracuda 1Tb in this case)
The components can be seen on this Ebay site:-
USB 2 0 TO SATA IDE Cable for HDD with Power Converter Adapter UK
The one thing missing from this set up is a power conversion cable converting the molar 4 pin power connector to a SATA power connector. These can be a molar plug to go into the lead from the black box and either a single SATA power plug, or a double SATA power connector as shown here :
Molex to 2x SATA Power Dual Power Adaptor Splitter Cable Lead Hdd Cd DVD...
This option is inexpensive and offers great flexibility in the type of drives that can be connected to a USB port, 2.5 or 3.5 inch, SATA or IDE.
In your particular case you may be able to get a dock that connects to a power supply and a USB port, with an opening in the top to take a SATA drive. These tend to be more expensive and only suitable for SATA drives not IDE.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Seagate Barracuda 7200.12 1 TB 7200rpm...
Hard disc is not getting recognized by the computer, although power light is appearing on the disc.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
if its an external hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 21, 2011 | Buffalo Technology Computers & Internet
The external drive does not show up on my desk top and it is plugged in.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
May 31, 2011 | Western Digital imicro IM35ST320SI 3.5 IDE...
My hard external hard drive is not detected by any pc I plug it into it powers up (gives noises and light) but it's not being detected please help thanks
Try using a different usb cord. If the device is still not working properly after that there may be an issue with the circuit board that attaches to the drive in the enclosure. If this may be the case you can purchase an new enclosure for the drive that comes with a new board for a reasonable cost. If you have a ide or sata to usb connector you may be be able to remove the hard drive from its enclosure and retrieve any data you may have stored on it. Here is a video I located on the web on retrieving your data. A few steps are unecessary if you have to ide to usb connector you will not need to disassemble your pc.
http://www.metacafe.com/watch/1000351/recover_data_from_external_hard_drive/
Mar 08, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I need a cord for the mad dog multi media device so that possibly I can have this external hard drive accessed.
What device do you need a cord for? The Mad Dog Dominator given above is an internal IDE CD/DVD drive. Thus it can be connected to a 4 pin peripheral molex connector to the power supply and a 40 pin IDE ribbon cable. Some USB/SATA/IDE devices will be able to connect to the drive for external use (since it is a full size 5 1/4" drive). Similarly, you can find some USB external device enclosures that will work with the IDE connect.
There are IDE to SATA converters that you can add to connect the drive to a computer with no IDE port on the motherboard. (There are also power adapters to convert a SATA power connector to the 4 pin in the rare case that you do not have a free 4 pin connector. However, a 4-pin y-connector is usually a better choice).
All of the above items are available from most computer supply shops.
I wish that I could be of more help.
(external hard drives currently can have one or more of the following connectors: USB 2.0, e-SATA, Firewire, ethernet, or USB 3.0. The USB 2.0 is the most common. A standard USB cable (A/B) is the usual one for a USB 2.0. These are also available at most computer shops. Look at the device and the size of the opening to determine the cable end needed. Standard B is a square end with beveled corners. Usually a text or icon on the device will indicate the port type.)
Oct 21, 2010 | Mad Dog Multimedia Dominator 4 in 1...
I had problems with my Maxtor One Touch III Mini. It was a loose connection from the USB cable on the Drive's end, and when I tried to solder it, I damaged the connector. Is there an alternative to get an...
If you damaged the external case you have two options. Remove the drive from it and put it in a new external or put the drive directly into your computer.
Here is a guide that will show you how to open your case.
If the hard drive is a SATA DRIVE you can just plug it right into your computer with SATA cables. If your drive an IDE DRIVE you're going to have to find an adapter in order to plug it into your computer as the IDE connection on these smaller drives aren't the same size as the connections on normal sized drives.
The easiest solution would be for you to find out what kind of drive it is, and then buy a compatible external case to put it in.
Mar 03, 2010 | Maxtor OneTouch III Mini Edition 120GB...
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Usb broke off my seagate 320gb external
it does'nt really matter IDE or SATA both are using same connector. you can change it from second hand or from another board sometimes its not available.
Sep 02, 2009 | Western Digital 320GB MyBook External USB...
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Fujitsu Siemens (MHV2060AH) 60 GB Hard Drive Logo
513 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
