Question about Cameras
I have an Avtech AVC783 stand alone DVR. It has a start up fault - when the power is connected it beeps twice per second & relay is clicking too. I suspect a power surge or power management area problem in the circuitry. Power supply is DC12-18V. I would like help on fault identification from tech experienced with DVR's. The repair options please.
trintek
  • 111 Answers
SOURCE: Sony Trinitron Power Surge 5 Blinks
once you have diagnosed the problem, the following link is to all parts for your tv stocked at partstore. they generally have better prices than the dealers and repair shops.
KV-36fs13 parts
you can try the dead-tv kit from fixyourowntv if you have some basic experience with soldering and circuit repair.
http://fixyourowntv.com/orderpage.php
Five blinks means, "IK (AKB)" (white balance). The probable causes listed by Sony are as follows:
1) Video OUT (IC561) is faulty (A board)
2) IC355 is faulty (A board)
3) Screen (G2) is improperly adjusted.
not sure what the 13 blinks are for.
hope this helps,
trin
Posted on Nov 19, 2007
  • 2318 Answers
SOURCE: where do I buy parts for gateway fpd1960
I'm sorry to say that in today's electronics devices, there is not much support anymore when It comes to service parts.
In many cases the same boards have to be fixed if you want that device to be functional again.
Posted on Mar 03, 2008
  • 142 Answers
SOURCE: Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Posted on Oct 17, 2008
hbsurfdawg
  • 95 Answers
SOURCE: Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Posted on Mar 02, 2009
gripfitter
  • 557 Answers
SOURCE: Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Posted on Dec 20, 2009
Kenwood a76 protect mode
hi, if protect comes up while the amp is standing alone without any speaker leads or input leads connected, then you definitely have an internal circuit fault, with either the power regulator circuits, or the amplfier circuits.
Jun 07, 2012 | Car Audio & Video
You had a post that said you had fixed faulty power relays on DSP-a1 - how do you identify the relays that need cleaning?
That your amp does not go into the second stage of powering up indicates a fault which is causing it to sit in non-active mode. This could be due to blown output audio module or transistors or a fault in the safety circuit itself. It is not a fault the non-technician can repair and it would need to be sent to an authorized workshop.
I have seen situations where users unknowingly leave frayed ends of wire shorting across the speaker output terminals which can lead to this sort of fault. You could check this out also.
Oct 28, 2011 | Yamaha DSP-A1 Receiver
Fuel pump relay fault Can't find relay. No power to fuel pump. Checked fuses. All good
Model? Year?
Check per owner manual to be sure inertia switch is not tripped. Remember, fuel pump only runs for 5 seconds when key is turned ON, then it shuts off if engine is not running. Pump always runs when key is in START position.
Listen for pump to run inside fuel tank for 5 seconds after key is ON.
The PCM power relay turns on the PCM and the PCM turns on the fuel pump relay, which turns on the fuel pump.
See owner manual forfuse & relay charts.
Apr 06, 2011 | Ford Expedition EL Cars & Trucks
Fisher & Paykel GWL10 begins to spin for about 15 to 20 seconds, just starts to pick up some speed, then machine beeps and shuts down. Seems like the water is draining. Any ideas? It has also been...
Yes it does seem like a control module fault.Bit concerned about the noise coming from the machine even thou it is not running.Please turn it off at the power point when not in use.Now if and when it faults again please reply back with error code as per 1st posting.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
I HAVE A SAMSUNG DVR SHR 2040 AND WAN TO VIEW FROM MY IPHONE IS THAT POSSIBLE
connect the iphone to the USB port of the DVR through the iphons data cable.just connect and enjy it.
Sep 11, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
I have a samsung 2082 every thank comes on but can not see it on a monitor, i know its not the rgb or the tv set up ,i have about 60 of the samsung dvr
First try,
Problem: All the front LEDs are in operation but the monitor remains black.
Solution: Video out may come out differently with the connected monitor. In short, Video
Out is set to Composite Output but connected to VGA Input Monitor or vice
versa. If the MODE and ZOOM buttons are pressed and hold for 5 seconds, the
system restarts while alarming beep sound.
Second and works 99.9% of the time but you have to reset all parameters
Factory Default will be done as follows;
- In Live mode, press and hold down MODE and then PTZ on the front panel for
6 seconds to reset all settings to factory.
Default menu password 4321
Jun 13, 2009 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Backup from Samsung DVR to CD
what type of media are you using?
Note
SHR-2040 supports the internal CD-R/W.
follow this process carefully
Backup
● If there is a device, the free space and the backup device is displayed.
● Select a date, time, and camera No. to backup, and press “Start”.
● When you change Start Date/Time or End Date/Time, free space keeps updated in
the Free Space zone.
● Afile name is composed of Folder/File Name. Afolder is composed of the backup
date(YYYYMMDD) while a file name is composed of the time(HHMM).
Afile may be renamed by the virtual keyboard. Afile name can composed of the
maximum 5 letters.
● In case that more than one backup device is connected, click the box in the
bottom of left corner to select a backup device.
● If there is no backup device, Warning sign pops up. Select and connect Backup
Device in 5-8.HDD Setup and proceed the backup.
● Press the “Stop” to stop the backup.
● Pressing Cancel during the Backup returns to the upper menu but this does not
affect the backup process.
● In case of USB HDD, the AVI check is impossible.
Caution
[In Backup Process]
Pressing THE “Cancel” returns to the upper menu but this does not affect Backup process.
Press “Stop” to stop the backup.
The speed of the set may down during the backup
mj
Sep 07, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
No sound output, regardless of channel selected, for 30-60 seconds
Hi Dan
The first click is the power relay connecting up the main transformer, the second click you normally hear is the speaker protection relay. When a fault condition is present in the amp, the protection circuit prevents the speakers connecting to the amp by NOT operating the relay. As the unit "settles" and works after the delay you noticed, what ever issue the amp is balancing itself it. It sounds like a leaky capacitor in transistor in the output stages. This can often be located with quick bursts of freeze coolant spray. It may also be a dry joint in the soldering about the driver and output transistors, always pays to have a visual look at it whilst you are in there. I also check power regulator stages for dry joints. The fault will be on one channel if it is signal path related, and both channels if power supply related. If you are familiar with electronic repairs, get in and have a look yourself. If not, get a NAD service guy to take a look at it for you. Good luck. Feel free to ask me any questions you may have about it.
regards
robotek
Aug 14, 2008 | NAD C370 2-Channel Amplifier
Cameras Logo
320 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
