Question about Honeywell Heating & Cooling
We had a brand new unit put in a couple of years back. When it was installed it worked. Once winter came, it obviously was turned off. Then the following summer, it would turn on but just blow air, would not cool at all- so the unit installers came out and repaired it. It worked through the summer, then the following summer-it wouldnt cool again-they came back out and fixed it again. Third summer in a row-it is not working again!! A friend told me this morning, on new units there is a reset button. Is this true?
    Master:
    Sergeant:
  • 449 Answers
Yes but you should have to keep resteting it you might have a major problem are you beiing charge for freon if so you have a bad condensor unit (it have a leak ) check your bill if the same thing happens again go see what the techs are doing
Posted on Sep 03, 2010
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
I tried to turn on my air coditioning today for the first time this year and my Totaline Themostat P474-1050 won't turn on. Worked fine during the winter and last summer.
the thermostat is powered by the unit or batteries if batteries they may be dead if the unit you need to check fuses outside at unit or reset breaker outside depending on age of installation
Jul 10, 2012 | Heating & Cooling
Cant get the mower to run after the prime is gone...any thoughts
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Aug 06, 2010 | Poulan "Poulan" Push Mower
The poulan mower HD4QN20RE does not want to saty
Be sure to use compressed air to blow out all fuel and air passages.
Please rate me,
Thanks
Good Luck,
I hope this helped
Jul 31, 2010 | Poulan "" Push Mower
Fan won't reverse though it has before
It could be 1 of 3 things. 1) Receiver unit, 2) Sender (Remote), 3) Motor. For my brand new ceiling fan it turned out it was the motor.
Jun 13, 2010 | Hampton Bay 24002 Ceiling Fan
When I turn on the unit the screen comes on then fades and diappears. This is a brand new unit installed by best buy.
It is obviously faulty so if you bought it new then return it to the store for a replacement or money back
Aug 30, 2009 | Car Audio & Video
Franklin BIB-1450 cannot turn on.
Turns out the batteries that I tried were dead. Bought new batteries and installed them. The Franklin BIB-1450 now works. Yay!
Jul 31, 2009 | Franklin BIB-1450
Craftsman 24Hp Lawn tractor engine dying out
1. check the oil level... don't want the auto shut off to be the problem due to low oil level
2. pull the carb bowl and check for residue. Spray out the needle valve in the carb, spray out the bowl and any jet openings you can find...spray them out too.
3.When you winterized, did you put fuel stabilizer in the tank? If not, drain the tank and refill with fresh...
4. check the air filter element and make sure it is clean...
let me know how it goes...
k
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Frige will not cool, have installed a t-stat. appears to have power to th eeye brow board. also installed a new coolant unit 3 years ago. the fridge worked whenput up for the winter but had to tap on the...
If you mean that you installed a compressor or put refrigerant in it, the unit that is, it could have a small leak and when you "put it up for the winter" it leaked out. When refrigerant is under pressure and on it will barely leak out if you have a small leak. They can go without a charge for a long time, but when you turn them off if they have a leak it will all leak out. Make sure you compressor is on and running. Once you put a refrigerator in service it is not really wise to "put them in storage." If you can keep from putting it in storage it would be better to leave them running at a little higher temperature setting. You won't be getting in and out of the unit as much because you won't be there to use it so it will not use as much electricity, but they are ment to stay plugged in and running once they are put into service.
May 12, 2009 | Refrigerators
Cooktop burner problem
Your plumber should know that the pipe service your cooker must be of a suitable size. Normal half inch pipe is only good for a couple of small burners. Most installations require one inch! There is a simple formulae for working out the flow rate of the gas. Your gas installer will know it.
Apr 18, 2017 | Cooktops
Heating & Cooling Logo
60 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
