Question about Frigidaire GLTF1670A Front Load Washer
Frigidaire Gallery Makes loud noise on final spin cycle. Sounds like it is coming apart and seems to go too fast.
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description of " Makes loud noise on final spin cycle", My first suspicion would be a worn tub bearing.
The other possibilities are the suspension shock absorbers have broken, or debris in the drain pump...hopefully. That is best case scenario.
**unplug the unit from the wall or turn off the breaker before proceeding...safety first**
The first place to start is to remove the access panel at the bottom. there will be two hex head 1/4" screws...one on each side.
example...
Once the access panel is removed, look for the shock absorbers, 1 on each side of the tub for a total of 2.
example...
Your may differ in appearance then my picture if original and be plastic cylinder shapes...but serve the same function. They've revised them since yours was built, New part # 134564200.
If they are intact, good...but bad.
Next, check the pump. This will require some towels, a shallow pan or even better, a wet dry shop-vac.Frigidaire Gallery Makes loud noise on final spin - 8a476e1.jpg /> example...
Remove the boot to the tub from the back and the two hex head/phiFrigidaire Gallery Makes loud noise on final spin - c45ce7a.jpg/16" screws holding the pump to the base.
example...
The next ( and worse ) possibility is as I alluded to the main tub bearing.
You can check this by way of opening the door and grabbing the inner basket rim and moving up and down to feel for play...there should be zero play or zero tolerance in this bearing.
You can also remove the rear panel and visually inspect it as well. First, look for signs of leakage around the center bearing.
Second, grab the large pulley and try and move it back and forth or spin it with the belt off to listen for a grinding noise.
If it is indeed worn it will require practically the complete tub assembly ( rear wall with bearing Frigidaire Gallery Makes loud noise on final spin - 6309280.jpgasket )...that is the least expensive and easiest fix at around $400 for the entire assembly.
example...
You can opt to change just the rear wall and bearing with the basket in separate pieces, but it comes in around $370 and still leaves you with pulling the old one apart to re-use the front shell.
Either way this is a fairly involved repair and even for an experienced tech like myself can take 60 - 90mins. I'd guess it would take one who's never done it all day.
Let me know what you find and I'll do what I can to assist you.
Good luck. Thank you for choosing FixYa. Please take a moment to rate the info I provided here for you.
Regards,
Macmarkus :)
Posted on Sep 03, 2010
  • Mike Conrad
    Mike Conrad Jan 26, 2014
    Macmarkus thank you. I googled this description and this information came up.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Frigidaire Gallery Series GLEH1642FS loud noise on final spin
It sounds like something has come loose or some item was placed in the unit accidentally and it got lodged in the drum. You will need to start by taking the front cover off and looking around the drum.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
My washer makes a loud noise in the spin cycle. It's a Frigidaire Gallery Washer Model 417.39012890. Any idea how expensive the repair will be?
In my experience with 417 Frigidaires is that when there is a noise in the spin cycle as you describe the drum bearing is failing. This is a very expensive repair that that when I looked up labor and parts could exceed 600 smakeroos.
Feb 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud noise on fast spin cycle
check the support rods holding the basket maybe one has been dislodged and givng you and unbalanced effect
Jan 09, 2009 | Frigidaire Washing Machines
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
4,114 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
