Question about Samsung LN-S3241D 32 in.LCD HDTV
Power okay, sound okay but screen black. - Samsung LN-S3241D 32 in.LCD HDTV
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Sep 03, 2010
Black screen on a gateway netbook
we need to know the following:
  1. is the fan running ?
  2. does the HDD spin or sound when you trun on
if the above is okay, we might suspect you lapmonitor - try connecting an external monitor then power up
Jan 16, 2013 | Computers & Internet
37" Toshiba TV (37av50u) no picture no sound?
Boards:
http://www.shopjimmy.com/catalogsearch/result/?q=TOSHIBA+37av50u
You need to check the DC output voltages on the power supply DC output connectors first.
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/s/fsp1884f05.jpg
Please read my guide to get some understanding.
Basic troubleshooting guide here:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 17, 2011 | Toshiba Televison & Video
Okay so first off I have ALOT of important docs and what not on my laptop so it is a must that I require these items ! okay So I just got back from Denver and had used my laptop only once and it worked...
Sounds like a graphic card problem. You should be able to remove your hard drive and connect it to a desktop computer and access the drive and get your important files.
Aug 06, 2010 | Toshiba Satellite A215-S5837 Notebook
No picture
chek caps in power supply
Apr 25, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
I have a 37' lcd westinghouse sound ok screen black
bad inverters on the panel ,the inverters usually come with the panel
Jun 11, 2009 | Televison & Video
Screens stay black, power lite is solid green
does it make the boot up sound? if so its a fault with your screen..can replace screens for £7.50 off ebay. try re- inserting ribbon cable for screen b4 buying new screen tho (could be that). if you can't hear bootup sound when powering up then something else wrong. maybe F1 or F2 fuse blown (test with a multi meter) look on youtube for tutorial
Mar 28, 2009 | Nintendo DS Lite Console
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Oct 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Black screen
Hi
did you get a solution for this problem as mine does exactly the same!
Thanks
jim.ross@virgin.net
Aug 22, 2008 | Relisys RLT1720 17" LCD Monitor
Screen black after big storm...
The set has sound and no picture.If you the SSB could be the issue but the tiny red dots on a black screen will need the panle replaced also. There is a way troble shooting can be done to determine if you will need the SSB or the SSB and the panel.
May 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
Samsung LN-S3241D 32 in.LCD  HDTV Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
