Question about Plumb Pak Home
How can I remove the locknut and washer to install a handle?
  • 43,501 Answers
A pump pliers is the best way but remember that the thread is left hand turning... opposite of normal...
heatman101
Posted on Sep 03, 2010
Adjusting shocks
To remove lift rear tire slightly off the ground then remove the shock attaching bolt and washer with a special Snap-On adapter PN SRES24 and then remove the flange locknut and washer with grommet at the front of the shock. To reinstall put the washer and grommet inside the frame and put the bushing over the stud end of the shock and put the stud end through the keyed frame tube and loosely install the flange locknut. THEN coat the shoulder of the shock bolt (1) with ANTI-SEIZE compound and the bolt threads with blue loctite and insert the bolt and washer through the shock end and pivot the shock to align the bolt and the hole in the rear fork. Then tighten the shock bolt with the Snap-on adapter and since the adapter is not going to be at 90 degrees to the torque wrench it will lengthen the torque wrench and therefore the torque value must be computed with a torque computer such as the Snap-On PN SS-306G.Tighten the bolt and washer at the rear to 115-130 ft-lbs (155.9-176.2 Nm) and tighten the flange locknutto 32-39 ft-lbs (43.4-52.9 Nm). Then adjust the shocks equally with a special shock adjustment spanner.
To adjust the shocks loosen the locknuts and turn the adjuster plates OUT towards the locknut to increase the spring preload for a heavier load or IN away from the locknut to decrease the spring preload for a lighter load. You should MARK the adjuster plates before you begin so you can know when you have equally adjusted both shocks to the same position.
Jun 29, 2014 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Not gating flam
follow this steps and fix it. God bless you
Service a compression faucet:
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Repair a reverse-compression faucet:
  2. Carefully pry off the trim cap with a small screwdriver and remove the handle screw. Unscrew the packing nut and lift out the stem assembly.
  3. As needed, pry out the washer under the packing nut and replace it.
  4. As needed, remove the seat washer and replace it with one that fits exactly. Rethread the spindle and washer back onto the stem, and reassemble the faucet.
Nov 30, 2013 | Plumbing
Thermostatic valve does not turn
followt this steps and fix it. God bless you
Nov 28, 2013 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
Keeps on pumping out water from the bowl even when there is no water in the bowl
Adjust or replace a flush handle:
  1. Remove the cover from the toilet tank (the higher part at the back of the toilet). If the handle is loose, tighten the locknut with a wrench. If the nut won't budge, apply penetrating oil and let it set before removing.
  2. Unhook the chain from the trip lever and slide the trip lever, with the handle attached, through the hole in the tank.
  3. Soak the handle threads in vinegar for an hour or so to remove mineral deposits, then scrub clean with an old toothbrush.
  4. Reinstall the assembly, tighten the locknut and adjust the lift chain (see below).
Adjust the lift chain:
  1. If the handle must be held down while the toilet is flushing, the chain may be too long. Shorten it by hooking the upper end through a different trip lever, or use long-nose pliers to open and remove some chain links. Alternately, replace the chain with a new one.
  2. Some flush assemblies have a lift wire instead of a chain. If the wire binds against its guide, flushing is impaired. Loosen the guide with a screwdriver, then adjust it so that the flush valve falls freely onto its seat.
Nov 24, 2013 | Home
I've changed rotors before but never on a 4 wheel drive. Could you tell me how to on a 1989 ford ranger?
Brake Rotor (Disc) - REMOVAL & INSTALLATION
  1. Loosen the wheel lug nuts.
  2. Jack up the front of the vehicle and support on jackstands.
  3. Remove the wheel and tire.
  4. Remove the brake caliper assembly as described earlier in this section, but do not disconnect the brake hose.
  5. Suspend the caliper assembly by a piece of wire. Do not allow it to hang by the brake hose.
  6. Follow the procedure given under wheel bearing removal in Suspension and Steering for models with manual and automatic locking hubs (lines down).
New rotor assemblies come protected with an anti-rust coating which should be removed with denatured alcohol or degreaser. New hubs must be packed with EP wheel bearing grease.
  1. Installation is the reverse of the removal procedure.
Front Wheel Bearings - REMOVAL & INSTALLATION
(see Figure 1 )
Fig. 1: Inspect the bearings for abnormal wear and/or damage
With Manual Locking Hubs
(see Figures 2 through 17)
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel and tire assembly.
  3. Remove the retainer washers from the lug nut studs and remove the manual locking hub assembly from the spindle.
  4. Remove the snapring and spacer from the end of the spindle shaft.
  5. Remove the outer wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
  6. Remove the locknut washer from the spindle.
  7. Remove the inner wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
  8. Remove the outer bearing cone and roller assembly from the hub. Remove the hub and rotor from the spindle.
  9. Using seal removal tool 1175-AC or equivalent remove and discard the grease seal. Remove the inner bearing cone and roller assembly from the hub.
  10. Clean the inner and outer bearing assemblies in solvent. Inspect the bearings and the cones for wear and damage. Replace defective parts, as required.
  11. If the cups are worn or damaged, remove them with front hub remover tool T81P-1104-C and tool T77F-1102-A or equivalent.
  12. Wipe the old grease from the spindle. Check the spindle for excessive wear or damage. Replace defective parts, as required.
Fig. 2: Before beginning the wheel bearing removal, and after the outer hub is removed, wipe off any excess grease
Fig. 3: After the grease is wiped off, remove the axle shaft snapring ...
Fig. 4: ... then pull the splined spacer from the axle shaft end
Fig. 5: Use a 4 pronged socket to loosen the outer wheel bearing locknut ...
Fig. 6: ... then remove the outer locknut
Fig. 7: Remove the lockwasher from behind the outer locknut ...
Fig. 8: ... then loosen and remove the inner locknut-note the lockwasher engagement pin (arrow)
Fig. 9: While pushing inwards on the rotor/hub assembly, remove the outer wheel bearing ...
Fig. 10: ... then pull the rotor/hub assembly from the spindle, taking care not to scratch the bearing cups in the hub
Fig. 11: Pry out the grease seal on the back of the rotor/hub assembly ...
Fig. 12: ... then remove the inner wheel bearing. Thoroughly clean and inspect all of the parts for wear or damage
continue...
Jul 29, 2011 | 1989 Ford Ranger
How to change fornt drivers wheel bearing on grand vitara 2002 model 2.0 ltr 5 door and where can i get a repair manual for this model
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Brake caliper and rotor
    • Locking hub or hub drive flange, if equipped
    • Hub grease cap, if equipped
    • Wheel speed sensor, if equipped
    • Wheel bearing lockwasher
    • Wheel bearing locknut and inner washer
    • Wheel hub and bearing assembly
    • Wheel hub oil seal
    • Wheel bearing oil seal
    • Snapring
  3. Press the wheel bearing and race out of the hub. To install:
  4. Press the wheel bearing and race into the hub so that the race is fully seated in the hub bore.
  5. Install or connect the following:
    • Snapring
    • Wheel bearing locknut and inner washer. Tighten the nut to 157 ft. lbs. (216 Nm).
    • Wheel bearing lockwasher. Tighten the retaining screws to 13 inch lbs. (1.5 Nm).
    • Front wheel
prev.gif next.gif --- Go to your local auto parts store or library to get a copy of the repair manual for this model.
Aug 26, 2010 | 2002 Suzuki Grand Vitara
Replace fuel pumpand moddual on a 2001 jeep wrangler sport 4.0l in side tank assembly
Fuel Pump Removal & Installation To Remove:
WARNING
The fuel system is under constant pressure, even when the engine is off. This pressure must be released before servicing the fuel pump module.
  1. Drain fuel tank and remove the tank.
  2. Thoroughly wash and clean area around pump module to prevent contaminants from entering tank.
  3. The plastic fuel pump module locknut is threaded onto fuel tank. Install special tool #6856 to fuel pump module locknut and remove locknut. The fuel pump module will spring up when locknut is removed.
  4. Remove the module from fuel tank.
To Install:
CAUTION
Whenever the fuel pump module is serviced, the module gasket must be replaced.
  1. Thoroughly clean locknut threads and mating fuel tank threads. Use a solution of soap and water. Do not use carburetor cleaner to clean threads.
  2. Using new gasket, position fuel pump module into opening in fuel tank.
  3. Apply clean water to locknut threads.
  4. Position locknut over top of fuel pump module.
  5. Rotate module until arrow is pointed toward front of vehicle (12 o'clock position). This step must be done to prevent float/float rod assembly from contacting sides of fuel tank.
  6. Install special tool #6856 to the locknut.
  7. Tighten the locknut to 55 ft-lb (74 Nm).
  8. Rotate fuel filter/fuel pressure regulator until its fitting is pointed to 10 o'clock position.
  9. Install the fuel tank.
Jul 17, 2010 | 2001 Jeep Wrangler
How do i remove the brake drum of a 1997 hyunidai excel do i need to remove the centre nut that also takes out the wheel bearing
With Rear Hub Bearing
  1. Raise the vehicle and support safely.
  2. Remove the wheels.
  3. Remove the dust cap, cotter pin and loosen the locknut
  4. Remove the washer and outer wheel bearing.
If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes.
  1. Remove the drum with the inner wheel bearing from the spindle.
To install:
  1. Install the drum on the spindle.
  2. Install the outer wheel bearing and washer.
  3. Tighten the locknut to 108-145 ft. lbs. (150-200 Nm). Turn the brake drum while tightening the spindle nut to seat the wheel bearings.
  4. Install the cotter pin and dust cap.
  5. Install the wheels
  6. Adjust the rear brakes.
Apr 23, 2010 | 1997 Hyundai Accent
Home Logo
54 people viewed this question
Top Plumb Pak Home Experts
john h
Tom Chichester
Are you a Plumb Pak Home Expert? Answer questions, earn points and help others
