Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Water stays in the top drawer, Cant be drained.
  • Fisher and P... Master
  • 3,247 Answers
You will have to clean the filter plate and drain sump.
If problem still there, then take the motor rotor out and clean the rotor cavity and the channel between the drain sump and rotor cavity.
Please rate this solution if it helped otherwise post a comment.
Posted on Sep 20, 2010
Samsung washer what does in mean water stays in the detergent dispenser after a wash..cant remove the cap on drain tube..
The detergent compartments for bleach, softener, and liquid are usually siphon activated. Remove the dispenser drawer by pulling it out all the way and depressing the release tab. Remove the compartment siphon caps and check that all parts are clean and free of debris, gunk, or grime. If the problem is still present, low rinse water pressure can be a likely cause preventing the siphon from working properly. You can manually activate the siphon by re installing all caps in the drawer, hold the detergent drawer over the kitchen sink, and pour a glass of water into each compartment till it overflows, wait to see if the respectively filled compartment then drains all but approx 1 teaspoon from it's self. If so your dispenser is fine. If the cap on the drain tube is the one at the bottom behind the access door that you are trying to remove, you should only do this if there is a need such as the unit not draining the water completely from inside the basket of cloths, or if you receive a long drain error.
Apr 17, 2014 | Washing Machines
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Maytag MAH8700AWW - detergent drawer full of water
try removing the drawer to see if one of your kids has put something in there
Dec 13, 2009 | Washing Machines
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
May 01, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
