Question about Sony VPL PX31 Multimedia Projector
Panasonic PT-L501U Projector will not display inputs from RCA or S-Video. I have checked input sources and settings. Projector will display menu screens but nothing else.
  • BigPhillip May 30, 2008
    I have the same problems with an SONY VPL-PX31, but it will display from my computer using VGA. Is this a mainboard problem or is is it locked in computer mode, somehow
  • BigPhillip May 11, 2010
    Big Phillip,
    It works great using VGA, displaying from my Laptop. I use the SONY Projector Station software and its receiving a Signal on the all of the inputs. It's works sometimes from the component output from my AV Receiver, but sometimes when I turn it on, it has the signal, but won't display a picture or may flicker and go blank. Its not the bulb (NEW)
    MainBoard ?
    Ballast ?
    Dust ?
    Help ME..........
  • 563 Answers
Does the VGA input work ?
If not then the Mainboard is at fault and will need either repair or replacement.
Posted on May 13, 2008
Is Panasonic projector PT-LB20U compliant with HDCP?
Since the PT-LB20U only has VGA, S-video and composite video inputs, it isn't HDCP compliant. You would need a device with DVI (sometimes), HDMI, or DisplayPort inputs. See page 15 for the connections available on the projector.
Panasonic has the manual for the projector on the product page: . The direct link to the manual is .
I wish that I had better news for you.
(the high definition copy protection details require the digital video signal capabilities of the newer inputs. Most digital to analog converters (HDMI to VGA, for example) do not support HDCP.)
Nov 26, 2015 | Panasonic Office Equipment & Supplies
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
Hi there, I'm having a strange problem that has really confused me and I'm sure it's something simple that's tripping me up but I can't figure this out. -Im not getting an image from any of my HDMI...
if you can select the hdmi inputs ok
and swap them around without a good result
if no image etc
you would expect there to be a default no signal message or error something on the viewing screen
if a total blank
could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
Apr 01, 2017 | Panasonic PT-AE3000U LCD Projector
I have a Panasonic PT-56DLX75. Remote and TV buttons can only turn TV on and off. No other buttons work so I cannot control volume or use menu for dvd. What are my options?
Try using another video input source to see if it is just the DVD player, or DVD input, also try using another set of RCA plugs, you would be surprised how many times 1 RCA connector goes bad.If no other input sources work and you are sure your cables are good, speak to a local Tech about possible main board/logic board repair/replacement.
May 20, 2013 | Televison & Video
Panasonic PT-AX200U projector. input display flashes on and off.
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Jan 08, 2013 | Panasonic PT-AX200U Projector
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Aug 21, 2010 | Panasonic PT-AX200U Projector
Have panasonic pt l701u projector using RCA input can't get picture can get sound. Tried changing settings and it didn't help.
Pleeaes connect Rca cable in Yellow port for video and white port for audio.
Also check input settings in projector Menu. it should be "video".
For your ref, diagram is below
Mar 25, 2010 | Panasonic PT L701U Multimedia Projector
Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Apr 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Sony VPL PX31 Multimedia Projector Logo
106 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
