Question about Frigidaire FEF336BC Electric Kitchen Range
My stove worked fine until I was getting the power to my house fixed yesterday and they turned off the power for about 8 hours. Now, the clock and the outlet on top work fine, but the burners, oven, and "element on" light don't work at all. What's up? Thanks.
  • mlandry81 Sep 03, 2010
    (It's not that model number, that was added automatically.)
    President:
  • 2,047 Answers
Considering the fact that the unit worked perfectly fine prior to the light being fixed the unit does not have any major problems.
In the course of the light being fixed a surge in power would have been probably fed into the house and therefore some of the fuses which supplies power to the part which is not functioning properly.
Get an expert to take a look at it if you are not a qualified electrical personnel. All they have to do is replace one of the numerous fuses in the unit which supplies power to the burners and oven.
Hope this solution has been helpful?
Posted on Sep 03, 2010
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Intex pool filter/ pump just stopped working
Try giving your pump more air circulation.
Turn off pump when not around it.(should only need to run for around 3 - 4 hours on a small (kid) pool 6 - 8 hours for standard house pool
You could put you pump on a timmer - set shut off time to just before you pump shuts down.
Check you pump (when not conected to mains power) - get some WD40 into it - (salt and metal no like each other)
Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Gas stove stopped working
Hi . I would begin by pulling the stove out and making sure it is plugged in. If it is, unplug it and plug something else into the plug like a blow dryer to make sure you have power to that outlet. If there is no power, you have either blown a fuse or kicked a circuit breaker. Go to your electrical panel to replace the fuse or reset the circuit breaker. good luck.
Feb 01, 2009 | Kenmore Kitchen Ranges
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do you set the clock on the panasonic cq-c1121u cd radio.
1 Turn the ignition switch until
the accessory indicator
lights.
2 Press [SRC] (PWR: Power).
3 Press [DISP] (CLOCK).
4 Hold down [DISP] (CLOCK) for more than
2 seconds.
5 Adjust the hour.
[[]: sets the hour ahead.
[]]: sets the hour back.
6 Press [DISP] (CLOCK).
7 Adjust the minute.
[[]: sets the minute ahead.
[]]: sets the minute back.
8 Press [DISP] (CLOCK).
Notes:
¡ "AdJ" is displayed before adjusting the clock.
¡ Hold down []] or [[] to change numbers rapidly.
power off displayPower Off
Press [DISP] (Display) to change the display.
Mar 10, 2008 | Audio Players & Recorders
Frigidaire FEF336BC Electric Kitchen Range Logo
64 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
