Question about Yard Machines Red Edger
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i remove my hand it stops looked at diafram looked ok whats the problem
    Problem Solver:
  • 5 Answers
Remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Posted on Sep 22, 2010
My mtd 3 hp edger wont start ,
does it have spark remove the plug hold nit near the head and pull the rope is there spark?
Apr 26, 2012 | Garden
Pontiac grand am (1996) wont start
Pontiac Grand am Don't waste your money on unnecessary sources and unwanted repairs. Get this manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc.
Dec 19, 2017 | 1996 Pontiac Grand Am
Mtd yard machine gas push edger wont stay running
It probably has dirt/obstruction in fuel system.locate carb.if it has a bowl on the bottom,remove and clean.also,if it is 2cycle,there is a filter in the fuel tank.if it is more than a few years old,replace it.check fuel lines.even a piece of debris you can't see will affect the operation.clean air filter after every 2nd use.when storing,do not empty fuel,use STA- BIL.replace spark plug.one or all of these steps should work.i am not doing this for $,i do it to help.i hope i have been helpful.bart.new jersey
Sep 20, 2011 | Garden
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
My Craftsman 26hp tractor is running extremely ruff, I have replaced the plugs Confirmed that the plugs are working. It runs ruff at all speeds. The tractor was runing just fine a few weeks ago
You've changed the plugs have you checked the oil and air filter if not you need to because if not it might need changed and it may be low the rider my father gave me ran ruff and would die in 5th gear and I changed the oil and air filter now it stays going in all gears.So my suggestion to you is to to change the oil and air filter I am not a pro but I have had to keep my mowers going no help from anyone so I had to learn so if you don't agree with me check with a repairman.
Apr 12, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Primer bulb has hole, how do I change it? Edger will not stay running, need to change primer bulb.
look in owners manual for correct size then go to your local BIG orange (" Home") store or its BIG blue (lowest) competitor. they have all kind and sizes available .usually just 4 small screws hold it in place.
Good Luck.
Mar 28, 2010 | Yard Machines Red Edger
THIS GAS EDGER HAS A PRIMER BULB. I PUSH IT THE RECOMMENDED TIMES. THE ENGINE STARTS AND RUNS FOR 5 SECONDS AND KILLS. I HAVE PULLED THE GAS TANK AND EMPTIED IT. REINSTALLED AND PUT IN FRESH GAS. I KNOW IT...
The jet in the carburetor is clogged if it is a 4 cycle unit or the diaphragms are stiff if in a 2 cycle unit. It is burning the primed fuel but can not draw any more fuel to burn to stay running.
HTH
Good Day
Nov 20, 2009 | Yard Machines Red Edger
Have to choke to keep running
this is not hard to do here is what you need , 1 can of carb cleaner anykind will do , a 10 mm rench to remove the bowl 7/16 socket . now remove the carb take a good look where the spring is before you take the carb off it muct go back in the same hole , now that you have it off take the bowl off remove the float place to the side here is the fun part look in the carb you will see some small hole spray them this will clean all of the old gas out if you can let it set for about 10 min then do it again blow out with air if you have one nothing else to do but reinstall this works most of the time ...Good Luck..
Aug 16, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Yard Machines Red Edger Logo
1,120 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
